I used the 5.8 GB full setup ZIP, over an existing 5.70 install without cleanup utility.
Only 2 files have a different date in the reports folder (Support/iv), License.txt and EarthworkReport.xslt.
I compared the EarthworkReport.xslt from 5.60.2, 5.70 and 5.70.1 with Notepad++ and compare plugin. They are all slightly different.
Examples
Left - 5.60.2 and Right 5.70
Left - 5.70 and Right 5.70.1
This Line for instance got changed for 5.70. But for 5.70.1 reverted back to what was in 5.60.2. But there are differences in other lines as well.
Sent: 08-01-2022 09:48
Subject: Stockpile/depression volumes in TBC 5.70
Apologies for the confusion. We are working internally to understand why this is still occuring for some users and not for others. I personally used Cleanup Utility then downloaded and installed using the online install link from this forum and am not seeing the issue.
Can you all tell me how you installed 5.70.1? Was it:
- "Check for Updates" in TBC
- Download of the offline install .zip package
- Download of the online install .exe
Charlie Sorg
Product Owner
Trimble Business Center, CIS
Sent: 07-31-2022 14:06
That is a known bug since 5.70.
https://community.trimble.com/discussion/earthwork-report-issues-v570#bma72ceecd-fcb4-40a1-8f57-5036817b6553
If it still doesn't work with 5.70.1 they haven't managed to fix it in time, before the patch release. A lot of people in the forum did downgrade to 5.6 because of that.
Sent: 07-29-2022 01:01
Hi Saif Bin Darwish
I checked in TBC 5.71 and got same issue, when using the Stockpile/Depression option my Earthworks report also shows no volume. When using the Surface to surface option it gives a volume as you mentioned. I will escalate this as a bug to the TBC Team to investigate and will give you feedback as soon as I get any update from them.
Albert Olivier
TBC Technical Product Manager
