Surface or Cut/Fill map export
  • 1.  Surface or Cut/Fill map export
    Posted 10-08-2022 15:32
    Hi, does anyone know how to export a cut fill/ surface so that it can be viewed in Autocad?
    I need to plot it with the plot template I have in Autocad.
    is frustrating that in other software such as LSS, you can export as a DWG and you see the coloured surface in autocad.
    when I try this in TBC I don't see this.
    I just want to see this in 2D so that I can plot a pdf using my Cad template.
    any ideas?
    Richard Childs
  • 2.  RE: Surface or Cut/Fill map export
    Posted 10-14-2022 02:46
    Hi Richard,
    It is relatively straightforward to import your CAD title block into TBC and then drop the Cut/Fill Map and Legend onto it, and then print to PDF. This is personally the route I would go.
    It is possible to create a georeferenced image from TBC of the Cut/Fill Map, which can then be inserted into CAD as another option.
    Best Regards, Richard.
    Richard Selby
  • 3.  RE: Surface or Cut/Fill map export
    Posted 10-16-2022 14:09
    personally, I think that exporting the cut fill map / faces is an important item to have as the creator of the map isn't always the end user.
    Importing a title block to TBC is great for easy outputs. I would suggest that data output from a system can be just as critical as data into a system.
    Richard - in regard to export of a georeferenced stored measurement. Do you know that process?
    ortho image exporter with no luck, Any assistance would be helpful.
    Regards,
    Julius
    Julius Newman
  • 4.  RE: Surface or Cut/Fill map export
    Posted 10-18-2022 16:51
    Thanks to Charlie at Trimble confirming this is an option.
    "Capture Image"
    This will export a JPG of the file with *.jgw and *kml data. That can then be imported into multiple cad packages.
    If using Autocad, you might need a lisp routine for the jgw, if using AutoCAD LT, you might have to coordinate points from the image and georeference that way (or export with a grid).
    Hopefully the attached helps.
    Regards,
    Julius
    Julius Newman
  • 5.  RE: Surface or Cut/Fill map export
    Posted 10-19-2022 01:05
    Hi Julius,
    You can use Create Plot Box first if you want more control over the captured area.
    Richard Selby
