I have seen this happen before on an early model SX10 in cluttered Wifi environments. To be fair to Trimble, Wifi is an open spec and not all kit plays nice. A replacement board (which I understand to have a newer radio chip) seems to handle these situations better, but as with all things radio, YMMV.
Alternatively, if you can, use the USB cable in the bottom of the case during scans. Or, try changing the WiFi channel in connection settings (free apps for your phone can tell you which channels are less cluttered).
Good luck!
Damo
Sent: 02-08-2023 22:58
Subject: SX10 often losing connection to TSC7 during scans
Has anyone come about solving this issue?
Having the same problem with my TSC7 and SX10 where the Wifi will disconnect while performing a scan.
Jake Linnett
