thank You very much and I will send the link to our dealer in Denmark.
Sent: 07-03-2024 23:04
Subject: TBC 2024 bugs - doesn't show Point Spreadsheet anymore
No problem. That way I also learn something new every day.
Feel free to send the forum link to your dealer. Otherwise, it might take even longer to get addressed. Maybe they are working on it already, users had complained here that 2024 is ignoring/deleting parts of multi-feature codes. It might be related.
Sent: 07-03-2024 22:54
Hallo Ronny
Thank You so much for Your help and effort.
I would like to send Your investigation to our Trimbledealer. Is this ok with You?
With kind regards
Carsten Merkel
Carsten Merkel
Sent: 07-03-2024 02:07
Hello Carsten,
something weird is going on with the feature codes processing/interpretation. From my perspective this is a bug in 2024.00 and needs to be investigated and addressed by the Trimble guys. Better send your project and bug report to your Trimble dealer.
If I open your project in 2023.11 it works, no error.
If I open your project in 2024 I also get that red cross and an exception when trying to open the point spreadsheet.
I've narrowed it down to the first point in the list "240624-001" and most likely it's feature code. But I also get the cross when trying to change the code for 240624-008. My suspicion is that they messed something up with the interpretation of numbers as feature codes.
If I disable that points vector, I can show the point spreadsheet and also the points properties. If I enable the vector I get the red cross.
While the vector is still disabled.
I can change the "feature" in the bottom feature section and the symbol will change, BUT it will not update the feature code in the upper section in 2024, it stays empty.
The following works in 2023.11 but not 2024.
Sent: 07-02-2024 23:23
Hello Ronny
Thanks for Your reply.
I created a new empty projekt and it seems to work.
Here one of my projekts, where TBC troubles me.
Carsten Merkel
Sent: 07-01-2024 03:42
Hello Carsten,
if I understand it correct it does happen with all your projects?
What happens if you create a new and empty project with no feature code list attached, and you manually just add one single point? Does it fail then as well?
Could you upload a small project file here or send me a link via private message?
Sent: 06-30-2024 22:13
Hallo Robert
I reinstalled TBC but it did'nt helped.
Carsten Merkel
Sent: 06-28-2024 09:38
A common instruction for something like this is to uninstall and reinstall TBC. One new version I had to reinstall because point clouds would not colorize. So it might be an error that occurred during installation.
Robert Hoy
