TBC 2024 removing second point code upon import
  • 1.  TBC 2024 removing second point code upon import
    Posted 06-26-2024 10:58
    So the issue we are having is when we have a point that is identified with 2 codes, when we import the .job file into TBC is is removing the second code.  example
    20027, 111912.925, 206400.216, 4942.216, LCW LCW2 B     so this line LCW  is continuing and LCW2 B beginning, this was not a problem in TBC 2023.11  now  upon import the "LCW2 B" is removed from the point code.
    Why is it now doing this.
    Robert Hintz
  • 2.  RE: TBC 2024 removing second point code upon import
    Posted 06-27-2024 15:05
    Hi Rob,
    How are you my friend? It has been too long.... I hope this message finds you well. The issue that you speak of here is a verified bug in the TBC v2024.00 software and will be fixed in the TBC patch release for this version. That version being 2024.01. I cannot comment on the release date of the patch but I would expect it sometime soon so be checking the "Check For Updates" tab in the TBC Support Ribbon often. Tell Von Neida I said hello and will stop by someday soon to say hello.
    Cheers,
    Tim Gillen
