We were also having some issues with 2024.01 including point cloud colourisation and some of the photogrammetry features. We initially downloaded and installed TBC 2024.01 using the online version. Short of reverting back to the stable 2023.11, After doing a full Trimble Clean UP and reinstallation from the offline install all the errors we were having with point clouds have been resolved. Sometimes we have found a coupld of reinstalls are required before our concerns are resolved.
Sent: 10-14-2024 08:43
Subject: TBC 2024.01 Crashing Point Cloud Registration
Hi Derek and Zach,
Thank you for your feedback. Regarding contacting my vendor support, we do often report these items to our vendor. We also place them hear, as the discussion tends to be much more involved and often includes Trimble folks input, which matters. Regarding rolling back software, it is time consuming and expensive. We expect updates to work.
I really do appreciate your help Zach. We do address the memory cache reliably as it resets with each install. Everything we do is by SSD and it is networked. Trimble can't expect in this day and age of servers and companies using mapped networked drives as standard operating procedure that operating on local machines is acceptable. It would create a nightmare of issue with chain of custody file preservation and organization. Almost every professionally consulting firm of more than a few survey staff that I have peers in uses some form of a mapped network drive with strict file and folder practice policies. Every other software we use does not have issues with this, and it has been normal practice to use mapped network drives since the early 2000's.
I will look into the affinity settings. I don't think anyone is running AMD CPU in my group. We have a muscle computer which has an AMD processor and we use for aerial imagery processing, which we do outside of Trimble software, it does have an installation of TBC, except we don't use it very often. I will look there at these affinity settings and I discover what they are. I think I have read some reporting on this, so I think your clue is enough for me to hunt it down.
Lastly, I will double check our location of our temp file. All of our workstations are solid state memory. But looking that the temp path may help anyhow.
Again, thank you for your input. We typically enjoy TBC and realize great success in efficiencies that get lost in Civil 3d when working with point clouds, so we need to continue to use it and use it successfully.
Thank you.
Clayton Bradshaw
Sent: 10-14-2024 07:07
Bizarre! I am not seeing any of this behavior. Are you sure that you are using using the max possible ram (Options-->Point Clouds-->Rendering memory cache size? Also, you are ONLY using an SSD drive and not a spinning or network drive, correct? Just trying to come up with any ideas here? If running AMD CPU, did you adjust the affinity settings? Lastly, is your temp directory pointing to a SSD drive or spinning/network? I would never use any network drives or spinning drives (for any reason really) with TBC. The same goes for any application that uses any amount of resources really.
Zach Edwards
Sent: 10-13-2024 14:07
Hey Clayton and Derek,
New releases bring a lot of new functionality, sometimes unforeseen issues can pop up. If a particular update isn't working for you, it shouldn't be too hard to roll back to a previous version that was more stable for your setup. Also, for more specific help, I'd recommend reaching out to your local Trimble dealer-they can connect with the dev team and get a deeper look at what's going on.
Ramin Rad
Sent: 10-11-2024 13:41
Hi Derek,
We have had the same. Lots and lots of issue. Saving problems, registration, import, etc. all when point clouds are involved. Bummer. And not much at all from Trimble folks on this.
Clayton Bradshaw
Sent: 10-11-2024 11:48
I am having a nightmare with point cloud registration since updating to 2024. A myriad of different errors come up. Can't import a simple e.57 file that I just exported myself from TBC.
derek copeland
Sent: 09-30-2024 08:44
As of my last post to this thread our department users have not updated to the
Version update: Trimble Business Center version 2024.01.1 now available
September 23, 2024
This does not list bug fixes as one of the reasons for its release though. So I have no reason to feel obligated to install and expect it to fix my issues and releasing updates as close to a month apart causes overhead expenses when this needs to be deployed/install/bug fixed on each team member's work station. Two releases a year is a reasonable expectation. Not one a month. Plus the unforeseen trickle down to Trimble Access that the new versions sometimes cause.
Trimble Team, Thank you for considering and responding.
Clayton Bradshaw
Sent: 09-30-2024 08:28
Trimble any input? This is critical. We can't operate like this and a bug this severe can't be issued to paying customers.
We are using the latest release and I don't believe we had any issues until we, as a department, installed this release. 2024.01, released this August.
The failure point is different from my team's users. Some cannot use the classify point cloud tool at all without complete and total failure and quit of the TBC program. TBC just disappears as if it wasn't even started, but it does leave behind the lock file. Other users can successfully get through each step of the registration tool, but at the point it is time to save, this causes a crash where TBC become unresponsive, but it doesn't disappear, just locks up. and sometimes we are able to get through the total classification process including refinement. Best luck is to do each step separate and limit the regions of interest to ground and then refine only ground. What a bummer.
We have installed, reinstalled, cleaned, reinstalled, on line install, off line install, etc. Any help is appreciated.
Clayton Bradshaw
Sent: 09-28-2024 07:13
Yes, I have. 2024 and 2024.1 have severe point cloud processing bugs.
Its not source dependent but some LAZ files are worse than others.
Classify ground usually works. Classify and refine ground almost never does and if it doesn't, you have to restart. If Classify/Refine finishes, sometimes it will put the point cloud in the wrong place or you'll actually drag it around on the screen when you pan/zoom.
2023 was almost flawless. But advanced point cloud filtering is so awesome, I've forgiven TBC for not fixing this for all of 2024.
I always use the TBC office utility to clean out previous installs before updating.
I went to a Wingtra lidar demo and the salesman had TBC point cloud classify crash on him. Never could get it to work. That had to be embarrassing.
Jordan Koehn
