TBC 2025.20 - Black Band in 3D View + Missing Axis Indicator (Verified Fix)
  • 1.  TBC 2025.20 - Black Band in 3D View + Missing Axis Indicator (Verified Fix)
    Posted 01-27-2026 09:31
    Symptoms
    • A solid black band appears at the bottom of the 3D View
    • It overlays the surface and does not rotate or resize
    • Background color changes do nothing
    • The 3D axis indicator (XYZ triad) is missing
    • Issue persists across projects and even after reinstalling TBC
    • Importing your old user profile brings the issue back
    Root Cause
    A graphics override stored in the user profile:
    File → Options → General → Display → Advanced → Graphics Display Driver →
    ☑ Override automatic detection
    When this box is checked, TBC forces a fixed internal rendering resolution that can:
    • Clip the bottom of the 3D View
    • Hide UI overlays (axis indicator, grid, etc.)
    • Break background rendering
    • Cause persistent black regions in the viewport
    This setting is saved to your user profile, so reinstalling TBC does not clear it.
    Verified Fix
    1. Go to: File → Options → General → Display → Advanced
    2. Under Graphics Display Driver, uncheck: "Override automatic detection"
    3. Click OK
    4. Restart TBC (not necessary)
    🎉 Result
    • Black band disappears
    • Axis indicator returns
    • Background color works normally
    • 3D View renders full frame
    • Issue does not return after resaving your profile
    🧠 Why this matters
    This is a subtle but impactful bug that only appears when:
    • A user profile carries forward old graphics overrides
    • TBC 2025.20's new rendering engine is forced into a non‑native mode (also appears in some older versions)
    • High‑DPI or multi‑monitor setups are involved
    testing confirmed:
    • Fresh install = clean
    • Import old profile = black band returns
    • Disable override = issue resolved
    • Resave profile = issue stays fixed
    Cain Derickson
