You have to download the offline version.
Unpack
Inside the package, you're going to see all the utilities or extensions independently.
Then see which apply for your region, and some of them are already installed in a new version.
The only one that did not installed is the "Trimble.Scs.Activities.API.Installer"
Leo Berrios
Sent: 07-16-2026 08:41
Subject: TBC 2026.10 / Local Dataset Workspaces API failed to start
how did you make it run again??
still here stuck with the api problem, cant install ANY TBC version, tried the last 5 version, non installed.
always errored out with the api error
Max Schmuttermair
Sent: 07-16-2026 06:02
Nothing Yet with the installer
Made it by installing one by one from the offline. Making sure which installer are needed per regions.
The API never installed, but TBC is running again. (At one point there was an issue about not recognizing the Folder projects)
Till now no issues.
Leo Berrios
Sent: 07-15-2026 10:39
Hey
I have the same issue
Something about my PC Window blocking the API installer.
I had tried many things.
Curious about, I used the installer into another PC and it had no issues.
But in this PC im trying harder to install it and it wont let me.
I had also used the Clean up utility, offline , online, no internet access with all of the firewall off . . . and still the API fails to start or to go thru. let me see if it is the HASP key
Leo Berrios
