Hi Zach,
was it an issue created by the drone or did the TBC processing cause the trouble?
Let us know, if the data is fine, but the baseline processing of TBC has a bug.
We hope you like the new features of TBC photogrammetry v2023 and newer. We added for this version a couple of new drones for baseline processing in TBC! The Skydio X10 series and the FreeFly drones! We also complemented the DJI drones.
Cheers,
Tom
Thomas Widmer
Sent: 11-23-2024 15:51
Subject: TBC 5.9 Adjust Photo Stations fails with error log file
Ok so it turns out that there are vastly varying elevations on the photos. A chunk show around 244m and the others show upwards of 2600m. It looks like the trajectory processing upstream from TBC was the culprit.
Zach Edwards
Sent: 11-23-2024 11:21
I know that I am late to the party but I am experiencing this for the first time as of yesterday. I was running 2024.01 and now I am on the latest (2024.10). Any suggestions here?
Edit....Ok so I deleted the UAS Box folder and then started TBC again and proceeded with the Relative Adjustment and it failed toward the end with a different error...
"[11/23/2024 11:35:36 AM] Error: Add GCPs to your project and measure them.
[11/23/2024 11:35:36 AM] Error: Child process Precise AT failed with exit code -19."
This is odd because these are images that are already PPKed and there are no GCPs.
Zach Edwards
