I have installed TBC 5.90.1 using the defaults. When a non-admin (general user) logs in, every 10 seconds a blue spinning circle appears next to the cursor. This does not happen when an admin is logged in. This occurs when TBC is both running and not running.
In the Windows Event Viewer the following 2 errors are present, which is also every 10 seconds.
Log Name: Application
Source: Application Error
Date: 10/23/2023 11:17:45 AM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: <redacted>
Description:
Faulting application name: Trimble.ExternalService.API.exe, version: 1.0.2.0, time stamp: 0x6387cc7a
Faulting module name: KERNELBASE.dll, version: 10.0.19041.3570, time stamp: 0xda674bb7
Exception code: 0xe0434352
Fault offset: 0x000000000002cf19
Faulting process id: 0x29ec
Faulting application start time: 0x01da05dd386d25d9
Faulting application path: C:\Program Files\Trimble\ExternalServiceApi\Trimble.ExternalService.API.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: a5488930-6e0d-41af-9f16-098efe1bc980
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
<Event xmlns=http://schemas.microsoft.com/win/2004/08/events/event>
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>100</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2023-10-23T18:17:45.7858696Z" />
<EventRecordID>70053</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Computer><redacted></Computer>
<Security />
</System>
<EventData>
<Data>Trimble.ExternalService.API.exe</Data>
<Data>1.0.2.0</Data>
<Data>6387cc7a</Data>
<Data>KERNELBASE.dll</Data>
<Data>10.0.19041.3570</Data>
<Data>da674bb7</Data>
<Data>e0434352</Data>
<Data>000000000002cf19</Data>
<Data>29ec</Data>
<Data>01da05dd386d25d9</Data>
<Data>C:\Program Files\Trimble\ExternalServiceApi\Trimble.ExternalService.API.exe</Data>
<Data>C:\WINDOWS\System32\KERNELBASE.dll</Data>
<Data>a5488930-6e0d-41af-9f16-098efe1bc980</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
Source: .NET Runtime
Event ID: 1026
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
Application: Trimble.ExternalService.API.exe
CoreCLR Version: 6.0.1322.58009
.NET Version: 6.0.13
Description: The process was terminated due to an unhandled exception.
Exception Info: System.UnauthorizedAccessException: Access to the path 'C:\ProgramData\Trimble\Trimble.ExternalService.API\config.json' is denied.
at Microsoft.Win32.SafeHandles.SafeFileHandle.CreateFile(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options)
at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize)
at System.IO.Strategies.OSFileStreamStrategy..ctor(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize)
at System.IO.Strategies.FileStreamHelpers.ChooseStrategyCore(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize)
at System.IO.Strategies.FileStreamHelpers.ChooseStrategy(FileStream fileStream, String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, Int64 preallocationSize)
at System.IO.StreamWriter.ValidateArgsAndOpenPath(String path, Boolean append, Encoding encoding, Int32 bufferSize)
at System.IO.File.WriteAllText(String path, String contents)
at Trimble.ExternalService.API.Helpers.GetApplicationUrl(String filePath)
at Program.<Main>$(String[] args)
Event Xml:
<System>
<Provider Name=".NET Runtime" />
<EventID Qualifiers="0">1026</EventID>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2023-10-23T18:17:45.6402531Z" />
<EventRecordID>70052</EventRecordID>
<Correlation />
<Security />
</System>
<EventData>
<Data>Application: Trimble.ExternalService.API.exe
</Data>
</EventData>
</Event>
James Cesari
