"TBC : Export : Corridor : Trimble Access road RXL templates" Issues found.
  • 1.  "TBC : Export : Corridor : Trimble Access road RXL templates" Issues found.
    Posted 03-29-2019 05:40
    I created a corridor using a very simple template ending to a Side slope targeting no surface.
    Exported RXL did not contain any Side slope. This case is possible using TGO RoadLink.
    So i tried creating a dummy surface which unintentionally  does not cover all the corridor. But this can be a real case scenario because it is quite often that a target surface does not give a daylight point.
    Exported RXL does contain Side slopes for the part of the corridor that target surface covers it.
    Also exist for the uncovered part !!! But templates miss the previous link so it is attached to the previous surface node which is obviously wrong!!!
    I have attached the whole project.
  • 2.  Re: "TBC : Export : Corridor : Trimble Access road RXL templates" Issues found.
    Posted 03-29-2019 15:35
    This is really a question for the Geospatial Team - in CEC Division we use SCS900 / Siteworks and that uses PRO Files which is a different solution for Corridors - the RXL format is only used by Access. Please reach out to my colleagues in the Geospatial Division through the Geospatial Forum for TBC to get their input on this specific problem - I apologize that I cannot really help as I am not so familiar with the Trimble Access workflows
  • 3.  Re: "TBC : Export : Corridor : Trimble Access road RXL templates" Issues found.
    Posted 03-30-2019 01:01
    I have to admit that i am kind of lost in the forums and i can figure out where is the right place to do it.
    Could you please provide me a link to transfer this question ?
    Also is it accepted to submit a question for Trimble Link for Civil 3D issues ? And if yes could you also provide me a link ?
  • 4.  Re: "TBC : Export : Corridor : Trimble Access road RXL templates" Issues found.
    Posted 03-30-2019 08:29
    Trimble link is a Geospatial product so the Geospatial Forum is the correct place to ask those questions.
    Civil 3D is not our product so we can try to answer some questions on supporting data from there or maybe on how to set up their system to send data to us
    The focus of this forum is the use of TBC for construction - while I can try to assist in other areas if I know the answers - when it crosses into areas where I don't use the products at all or often I don't have the time to research the problems unfortunately
    Sent from my iPhone
  • 5.  Re: "TBC : Export : Corridor : Trimble Access road RXL templates" Issues found.
    Posted 03-30-2019 09:03
    Community.Trimble.Com is the main Geospatial Community for TBC - there are currently sub spaces like this TBC for Construction - soon however these will be merged into one Community Forum so both Construction and Geospatial staff will be tracking the same site and answering both types of question.
    Thanks
    Sent from my iPhone
  • 6.  Re: "TBC : Export : Corridor : Trimble Access road RXL templates" Issues found.
    Posted 03-30-2019 15:08
    Here is the URL for the Geospatial Forum
    https://community.trimble.com/community/find-answers/content
    Here is the URL for the TBC for Construction Forum
    https://community.trimble.com/community/find-answers/civil-engineering-and-construction/business-center-hce
    On Sat, Mar 30, 2019 at 2:01 AM tassosvidouris@yahoo.gr <trimble@jiveon.com>
  • 7.  Re: "TBC : Export : Corridor : Trimble Access road RXL templates" Issues found.
    Posted 04-04-2019 00:45
    Thank you for your answers to all my posts.
  • 8.  RE: Re: "TBC : Export : Corridor : Trimble Access road RXL templates" Issues found.
    Posted 11-02-2023 08:29
    This looks to be a specific query best suited for the Geospatial Team's expertise in SCS900, Siteworks, and Trimble Access workflows." Directing this to TBC's Geospatial Forum might give useful information.
    Aarav sharma
  • 9.  RE: Re: "TBC : Export : Corridor : Trimble Access road RXL templates" Issues found.
    Posted 11-03-2023 06:17
    This particular inquiry seems tailored for the Geospatial Team, specializing in SCS900, Siteworks, and Trimble Access workflows. Redirecting to TBC's Geospatial Forum could yield valuable insights and information.Nrega Job Card List
    Susmita Roy
