thanks Ronny, have used the IFC's in access, but more or less as a visual aid, did go little deeper into what access can do with IFC's, and yes its possible to use points from the meshified IFC to get a position/bearing and slope angle, you will not get the centre of a bolt thoh(no vertex there), just the edge verticies on the mesh are points that can be used, so for concrete piles it is perhaps good enough, for millimeter precision you might want to prepare a line that sits exactly as theoretical,
yes, the IFC explode, perhaps better off explode the damn thing first
and the line extraction was for the high voltage power lines type of thing(?)
Cheers!
Kåre Jakobsson
Sent: 12-16-2022 19:01
Subject: TBC extract piles/truss beams from IFC's etc to Access and scan extraction
Why don't you use the IFC directly in Access?
The other option is the macro "explode IFC"? That will create all the linework that the IFC is made of. That is a Trimble macro and is included since several versions.
