Simply select Register a mission with the Global option. As mentioned in the TBC 2025.10 release notes:
Mission Registration - The enhancement to the Global adjustment method now
allows the same offset to be applied to all runs, rather than to those adjusted with
the Ground Control Points (GCPs).
Vincent Fortier-Richer
Sent: 10-23-2025 12:10
Subject: TBC mobile mapping workflow
Vincent,
Any help on how to locate this option ("rigidly move all mission data to control in a registration and after a LiDAR QC adjustment session") would be helpful. I am using v2025.10. Tried the "global" registration but the cloud still gets either lifted above or place below the GCP. I've tried locking only x&y on the areas that the vertical is bad but got the same result.
Can you point me to a workflow that would be helpful to use this feature to it's full potential.
Thank You
Kyle Braga
Kyle
Sent: 07-04-2025 13:43
Hi Mark, this is a known issue. As mentioned in this power hour, the next TBC release (2025.01) will include the possibility to "rigidly move all mission data to control in a registration and after a LiDAR QC adjustment session". Meanwhile, have you tried selecting the "global" registration type (rather than "local" or "global than local")?
