Alan,
I have seen some similar issues, can you maybe send over an example data set, add a link
Ideally go through the dealer who can send a case to us in support?
Attn Alan Cliff might get it to me!
Alan Cliff
Sent: 02-17-2025 01:02
Subject: TBC plotter line weight differences
I only got advice from my local supplier and that was to use PDF – nothing from Trimble
Cheers
Alan Walters| | Survey Instructor
Construction Division| MKC Training
Sent: 2/14/2025 3:19:00 PM
Subject: RE: TBC plotter line weight differences
Hey - did you ever hear back about this? I'm having a similar issue. Something is screwy with the text lineweight. If you want it to plot with any thickness at all (v 2024.10) - you have to set to lineweight 0.00. But that won't work for items like line/point labels - since you cannot adjust those lineweights. Even weirder - we've plotted the exact same sheet within 2 minutes apart, using the same version of TBC, but from different laptops & the lineweights do not match eachother. We just recently switched from using AutoCAD to TBC for our plot plans - but this kind of bug is making us second guess that decision. Can someone from Trimble please look into this??? We are plotting plan sets, direct to PDF
Ken Herwig
