In recent weeks I've noticed that everytime I try to process baselines from static observations with ultrarapid ephemeris TBC produces an error message. It stops the baseline processing and no vectors are computed.
As soon as I remove the utrarapid ephemeris file from the project it processes normally. It does not produce any error if I use the rapid or final ephemeris.
I'm working with TBC version 5.7. License is expired.
Below the error message. Thank you.
(Inner Exception)
Exception Count: 3
Exception Source: Trimble.Sdk.Coordinates
Exception Type: System.IndexOutOfRangeException
Exception Message: Index was outside the bounds of the array.
Exception Target Site: <GetReferenceFrameID>b__20_2
---- Stack Trace ----
Trimble.Vce.Coordinates.CoordinateSystemDefinition.<>c.<GetReferenceFrameID>b__20_2(String[] pair)
Trimble.Sdk.Coordinates.DLL : N 00024
System.Linq.Enumerable.ToDictionary(IEnumerable`1 source, Func`2 keySelector, Func`2 elementSelector, IEqualityComparer`1 comparer)
System.Core.dll : N 00270
Trimble.Vce.Coordinates.CoordinateSystemDefinition.TDDCoordTransformer.GetReferenceFrameID(String nameOrAliasOrAuthorityID)
Trimble.Sdk.Coordinates.DLL : N 01966
Trimble.Vce.Data.GNSSProcessor.GNSSProcessor.CreateSessionParameters(ProcessData data)
Trimble.Vce.Data.GNSSProcessor.DLL : N 00294
Trimble.Vce.Data.GNSSProcessor.GNSSProcessor.翈(ProcessData A_0)
Trimble.Vce.Data.GNSSProcessor.DLL : N 00255
Trimble.Vce.Data.GNSSProcessor.GNSSProcessor.ProcessSingleBaseline(ProcessData processData)
Trimble.Vce.Data.GNSSProcessor.DLL : N 00632
Trimble.Vce.Data.GNSSProcessor.纎.絔(Task[] A_0)
Trimble.Vce.Data.GNSSProcessor.DLL : N 00261
System.Threading.Tasks.<>c.<ContinueWhenAllImpl>b__57_1(Task`1 completedTasks, Object state)
mscorlib.dll : N 00074
System.Threading.Tasks.ContinuationResultTaskFromResultTask`2.InnerInvoke()
mscorlib.dll : N 00179
System.Threading.Tasks.Task.Execute()
mscorlib.dll : N 00071
(Outer Exception)
Exception Count: 3
Exception Source: mscorlib
Exception Type: System.AggregateException
Exception Message: One or more errors occurred.
Exception Target Site: WaitAll
System.Threading.Tasks.Task.WaitAll(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken)
mscorlib.dll : N 01264
Trimble.Vce.Data.GNSSProcessor.GNSSProcessor.CreateProcessingTasks()
Trimble.Vce.Data.GNSSProcessor.DLL : N 02895
Trimble.Vce.Data.GNSSProcessor.GNSSProcessor.Process(BackgroundWorker backgroundWorker, DoWorkEventArgs workEventArgs)
Trimble.Vce.Data.GNSSProcessor.DLL : N 00396
Trimble.Vce.UI.PPCommands.<>c__DisplayClass40_0.<BeginProcessingBaselines>b__0(Object workerSender, DoWorkEventArgs workEventArgs)
Trimble.Vce.UI.PPCommands.DLL : N 00151
System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
System.dll : N 00155
Trimble.DiskIO.UEReportingBackgroundWorker.OnDoWork(DoWorkEventArgs e)
Trimble.Sdk.DiskIO.DLL : N 00019
Date and Time: 10/02/2024 08:40:39
Machine Name: DESKTOP-ISMA-KT
IP Address: fe80::18ea:2c0:a0bb:4002%4, fe80::d551:d5aa:1943:94e0%2, 192.168.56.1, 192.168.2.107,
Current User: DESKTOP-ISMA-KT\ismak
Application Domain: TrimbleBusinessCenter.exe
Thread Name: BaseLine Processing
---- Assemblies in AppDomain ----
Assembly Full Name: mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Assembly Full Name: TrimbleBusinessCenter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleBusinessCenter.exe
Assembly Full Name: Trimble.Vce.UI.Controls, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.DLL
Assembly Full Name: System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
Assembly Full Name: System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Assembly Full Name: System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Assembly Full Name: Trimble.Vce.UI.UIManager, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.UIManager.DLL
Assembly Full Name: Trimble.Sdk.Interfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Interfaces.DLL
Assembly Full Name: netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/netstandard/v4.0_2.0.0.0__cc7b13ffcd2ddd51/netstandard.dll
Assembly Full Name: Trimble.Sdk.DiskIO, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.DiskIO.DLL
Assembly Full Name: Trimble.Vce.UI.Client, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Client.DLL
Assembly Full Name: System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Assembly Full Name: System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Assembly Full Name: System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Assembly Full Name: Infragistics4.Win.UltraWinDock.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinDock.v20.1.DLL
Assembly Full Name: Trimble.Vce.UI.BaseCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.BaseCommands.DLL
Assembly Full Name: Trimble.Sdk.Data, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Data.DLL
Assembly Full Name: Trimble.Vce.DeviceIo, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.DeviceIo.DLL
Assembly Full Name: Trimble.Vce.Services.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Construction.DLL
Assembly Full Name: Trimble.Vce.Services.Tcc, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Tcc.DLL
Assembly Full Name: Trimble.Sdk.Properties, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Properties.DLL
Assembly Full Name: Trimble.Vce.Data.DWG, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DWG.DLL
Assembly Full Name: TD_SwigCoreMgd, Version=22.2.0.0, Culture=neutral, PublicKeyToken=8e28356228e490a2
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TD_SwigCoreMgd.DLL
Assembly Full Name: TD_SwigDbMgd, Version=22.2.0.0, Culture=neutral, PublicKeyToken=5ccc28765cdf0a88
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TD_SwigDbMgd.DLL
Assembly Full Name: Trimble.Vce.Data.SDE, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SDE.DLL
Assembly Full Name: Trimble.Sdk, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.DLL
Assembly Full Name: Infragistics4.Win.UltraWinToolbars.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinToolbars.v20.1.DLL
Assembly Full Name: Trimble.Vce.ViewModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ViewModel.DLL
Assembly Full Name: System.Reactive, Version=5.0.0.0, Culture=neutral, PublicKeyToken=94bc3704cddfc263
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Reactive.DLL
Assembly Full Name: Trimble.Vce.TbcLicense, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.TbcLicense.DLL
Assembly Full Name: Trimble.Vce.Services.Auth, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Auth.DLL
Assembly Full Name: Trimble.Sdk.Geometry, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Geometry.DLL
Assembly Full Name: Trimble.Sdk.Utilities, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Utilities.DLL
Assembly Full Name: Trimble.Identity, Version=4.0.1.0, Culture=neutral, PublicKeyToken=33101ee013558559
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Identity.DLL
Assembly Full Name: Trimble.Diagnostics, Version=2.0.5.0, Culture=neutral, PublicKeyToken=33101ee013558559
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Diagnostics.DLL
Assembly Full Name: Microsoft.Diagnostics.Tracing.EventSource, Version=1.1.28.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Diagnostics.Tracing.EventSource.DLL
Assembly Full Name: System.Net.Http, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
Assembly Full Name: Microsoft.Extensions.DependencyInjection.Abstractions, Version=5.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.DependencyInjection.Abstractions.DLL
Assembly Full Name: Trimble.Vce.Hub, Version=1.0.4.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Hub.DLL
Assembly Full Name: Newtonsoft.Json, Version=13.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Newtonsoft.Json.DLL
Assembly Full Name: Infragistics4.Win.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.v20.1.DLL
Assembly Full Name: Microsoft.AspNetCore.SignalR.Client.Core, Version=5.0.7.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Client.Core.DLL
Assembly Full Name: WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
Assembly Full Name: Microsoft.AspNetCore.SignalR.Common, Version=5.0.7.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Common.DLL
Assembly Full Name: Microsoft.AspNetCore.SignalR.Client, Version=5.0.7.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Client.DLL
Assembly Full Name: Microsoft.Bcl.AsyncInterfaces, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Bcl.AsyncInterfaces.DLL
Assembly Full Name: System.Threading.Tasks.Extensions, Version=4.2.0.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Threading.Tasks.Extensions.DLL
Assembly Full Name: hasp_net_windows, Version=8.2.56087.60000, Culture=neutral, PublicKeyToken=56120be447701319
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/hasp_net_windows.DLL
Assembly Full Name: Microsoft.AspNetCore.Http.Connections.Common, Version=5.0.7.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.Http.Connections.Common.DLL
Assembly Full Name: Microsoft.Extensions.DependencyInjection, Version=5.0.0.1, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.DependencyInjection.DLL
Assembly Full Name: Microsoft.Extensions.Logging, Version=5.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Logging.DLL
Assembly Full Name: Microsoft.AspNetCore.SignalR.Protocols.Json, Version=5.0.7.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Protocols.Json.DLL
Assembly Full Name: Microsoft.Extensions.Options, Version=5.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Options.DLL
Assembly Full Name: Microsoft.Extensions.Logging.Abstractions, Version=5.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Logging.Abstractions.DLL
Assembly Full Name: Microsoft.AspNetCore.Connections.Abstractions, Version=5.0.7.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.Connections.Abstractions.DLL
Assembly Full Name: System.Memory, Version=4.0.1.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Memory.DLL
Assembly Full Name: System.Text.Json, Version=5.0.0.2, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Text.Json.DLL
Assembly Full Name: Microsoft.AspNetCore.Http.Connections.Client, Version=5.0.7.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.Http.Connections.Client.DLL
Assembly Full Name: System.Text.Encodings.Web, Version=5.0.0.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Text.Encodings.Web.DLL
Assembly Full Name: System.Runtime.CompilerServices.Unsafe, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Runtime.CompilerServices.Unsafe.DLL
Assembly Full Name: Microsoft.Extensions.Primitives, Version=5.0.0.1, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Primitives.DLL
Assembly Full Name: System.ValueTuple, Version=4.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ValueTuple/v4.0_4.0.0.0__cc7b13ffcd2ddd51/System.ValueTuple.dll
Assembly Full Name: System.Runtime.InteropServices.RuntimeInformation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.InteropServices.RuntimeInformation/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.InteropServices.RuntimeInformation.dll
Assembly Full Name: System.Threading.Channels, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Threading.Channels.DLL
Assembly Full Name: System.IO.Pipelines, Version=5.0.0.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.IO.Pipelines.DLL
Assembly Full Name: Microsoft.AspNetCore.Http.Features, Version=5.0.7.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.Http.Features.DLL
Assembly Full Name: Trimble.Sdk.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Core.DLL
Assembly Full Name: System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
Assembly Full Name: Trimble.Trdm.ServiceManagement, Version=2.16.8.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Trdm.ServiceManagement.DLL
Assembly Full Name: Loupe.Agent.NETCore, Version=4.11.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Loupe.Agent.NETCore.DLL
Assembly Full Name: Loupe.Core.NETCore, Version=4.11.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Loupe.Core.NETCore.DLL
Assembly Full Name: Loupe.Extensibility.NETCore, Version=4.11.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Loupe.Extensibility.NETCore.DLL
Assembly Full Name: System.Runtime.Serialization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
Assembly Full Name: System.Numerics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
Assembly Full Name: DotNetZip, Version=1.15.0.0, Culture=neutral, PublicKeyToken=6583c7c814667745
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/DotNetZip.DLL
Assembly Full Name: Infragistics4.Shared.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Shared.v20.1.DLL
Assembly Full Name: Infragistics4.Win.Misc.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.Misc.v20.1.DLL
Assembly Full Name: UIAutomationProvider, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
Assembly Full Name: UIAutomationTypes, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
Assembly Full Name: Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Assembly Full Name: Trimble.Vce.Data.Machine, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Machine.DLL
Assembly Full Name: System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
Assembly Full Name: Trimble.Sdk.SCS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.SCS.DLL
Assembly Full Name: Trimble.CoreX.CSD, Version=2.91.10.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.CoreX.CSD.DLL
Assembly Full Name: Autofac, Version=6.1.0.0, Culture=neutral, PublicKeyToken=17863af14b0044da
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Autofac.DLL
Assembly Full Name: Trimble.Trdm.Contracts, Version=2.16.8.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Trdm.Contracts.DLL
Assembly Full Name: System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
Assembly Full Name: SMDiagnostics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
Assembly Full Name: System.ServiceModel.Internals, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
Assembly Full Name: System.ServiceModel.Primitives, Version=4.9.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.ServiceModel.Primitives.DLL
Assembly Full Name: System.IdentityModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll
Assembly Full Name: Trimble.Vce.InjectDependencies, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.InjectDependencies.DLL
Assembly Full Name: Trimble.Sdk.Configuration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Configuration.DLL
Assembly Full Name: Autofac.Extensions.DependencyInjection, Version=7.1.0.0, Culture=neutral, PublicKeyToken=17863af14b0044da
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Autofac.Extensions.DependencyInjection.DLL
Assembly Full Name: Microsoft.Extensions.Configuration.Abstractions, Version=5.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Configuration.Abstractions.DLL
Assembly Full Name: Microsoft.Extensions.Configuration, Version=5.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Configuration.DLL
Assembly Full Name: Loupe.Extensions.Logging, Version=4.11.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Loupe.Extensions.Logging.DLL
Assembly Full Name: Trimble.Vce.Data.Import, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Import.DLL
Assembly Full Name: Trimble.Vce.UI.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Reports.DLL
Assembly Full Name: Trimble.Vce.GraphicsEngine2D, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GraphicsEngine2D.DLL
Assembly Full Name: Trimble.Vis.PdfImporter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.PdfImporter.DLL
Assembly Full Name: System.Drawing.Common, Version=4.0.0.2, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Drawing.Common.DLL
Assembly Full Name: Trimble.Sdk.Units, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Units.DLL
Assembly Full Name: Trimble.Sdk.Alignment, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Alignment.DLL
Assembly Full Name: PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
Assembly Full Name: PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
Assembly Full Name: ReactiveUI, Version=15.1.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/ReactiveUI.DLL
Assembly Full Name: Splat, Version=12.1.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Splat.DLL
Assembly Full Name: Trimble.Sdk.Persistence, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Persistence.DLL
Assembly Full Name: Trimble.Sdk.Coordinates, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Coordinates.DLL
Assembly Full Name: Trimble.Sdk.Surface, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Surface.DLL
Assembly Full Name: Trimble.Vce.Epm, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Epm.DLL
Assembly Full Name: Trimble.Vce.Data.REB, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.REB.DLL
Assembly Full Name: Trimble.Vce.Data.ComputationEngine2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ComputationEngine2.DLL
Assembly Full Name: Trimble.Core.CSDUI.MVP, Version=3.2.0.0, Culture=neutral, PublicKeyToken=012f2610d490fd1a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Core.CSDUI.MVP.DLL
Assembly Full Name: Trimble.Core.CSD, Version=2.91.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Core.CSD.DLL
Assembly Full Name: Trimble.Vce.Services.Tbc, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Tbc.DLL
Assembly Full Name: Trimble.Vce.Data.LandXML, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.LandXML.DLL
Assembly Full Name: Trimble.Vce.Data.Kml, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Kml.DLL
Assembly Full Name: Trimble.Vce.UI.Wpf, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Wpf.DLL
Assembly Full Name: CefSharp, Version=99.2.90.0, Culture=neutral, PublicKeyToken=40c4b6fc221f4138
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/CefSharp.DLL
Assembly Full Name: ReactiveUI.Wpf, Version=15.1.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/ReactiveUI.Wpf.DLL
Assembly Full Name: Trimble.Vce.UI.ScanningCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScanningCommands.DLL
Assembly Full Name: Trimble.Vce.UI.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Hoops.DLL
Assembly Full Name: Trimble.eCog.API, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.eCog.API.DLL
Assembly Full Name: Sde.NET, Version=3.2.0.3518, Culture=neutral, PublicKeyToken=fa7d95db1187f161
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Sde.NET.DLL
Assembly Full Name: Trimble.Vce.UI.Controls.PropertyGrid, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.PropertyGrid.DLL
Assembly Full Name: Trimble.Sdk.ForeignCad, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.ForeignCad.DLL
Assembly Full Name: WindowsFormsIntegration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
Assembly Full Name: Trimble.Vce.Scanning, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Scanning.DLL
Assembly Full Name: Trimble.Sdk.MobileMapping, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.MobileMapping.DLL
Assembly Full Name: Microsoft.Practices.EnterpriseLibrary.Validation, Version=6.0.0.0, Culture=neutral, PublicKeyToken=9d493c709b8014cc
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.EnterpriseLibrary.Validation.DLL
Assembly Full Name: System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
Assembly Full Name: Infragistics4.Win.UltraWinEditors.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinEditors.v20.1.DLL
Assembly Full Name: Trimble.Vce.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Hoops.DLL
Assembly Full Name: Trimble.Sdk.GraphicsModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.GraphicsModel.DLL
Assembly Full Name: hoops_mvo2620_cs141, Version=26.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/hoops_mvo2620_cs141.DLL
Assembly Full Name: hics2620_cs141, Version=26.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/hics2620_cs141.DLL
Assembly Full Name: Trimble.Sdk.Bridge, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Bridge.DLL
Assembly Full Name: hoops_stream2620_cs141, Version=26.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/hoops_stream2620_cs141.DLL
Assembly Full Name: Trimble.Vce.GE.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Core.DLL
Assembly Full Name: System.Configuration.ConfigurationManager, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Configuration.ConfigurationManager.DLL
Assembly Full Name: Trimble.Vce.UI.MonitoringCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.MonitoringCommands.DLL
Assembly Full Name: Trimble.Vce.Monitoring, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Monitoring.DLL
Assembly Full Name: Infragistics4.Win.UltraWinGrid.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinGrid.v20.1.DLL
Assembly Full Name: Trimble.Sdk.Monitoring, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Monitoring.DLL
Assembly Full Name: Trimble.Vce.Services.Monitoring, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Monitoring.DLL
Assembly Full Name: Trimble.Vce.UI.ConstructionCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionCommands.DLL
Assembly Full Name: Trimble.Sdk.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Construction.DLL
Assembly Full Name: Trimble.Vce.UI.ConstructionReports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionReports.DLL
Assembly Full Name: Infragistics4.Win.UltraWinTree.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTree.v20.1.DLL
Assembly Full Name: Trimble.Vce.Functions.SCS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Functions.SCS.DLL
Assembly Full Name: Infragistics4.Win.UltraWinChart.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinChart.v20.1.DLL
Assembly Full Name: Infragistics4.Win.UltraWinListView.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinListView.v20.1.DLL
Assembly Full Name: Trimble.Vce.UI.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Construction.DLL
Assembly Full Name: System.Runtime.Caching, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Caching/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.Caching.dll
Assembly Full Name: Trimble.Sdk.Primitives, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Primitives.DLL
Assembly Full Name: NTJV.UI.Commands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/NTJV.UI.Commands.DLL
Assembly Full Name: NTJV.ViewModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/NTJV.ViewModel.DLL
Assembly Full Name: Microsoft.Win32.Registry, Version=4.1.3.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Win32.Registry.DLL
Assembly Full Name: Trimble.Vce.MobileMapping, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.MobileMapping.DLL
Assembly Full Name: Trimble.Vce.Data.GIS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GIS.DLL
Assembly Full Name: DataInteroperabilityComponent, Version=1.4.0.6, Culture=neutral, PublicKeyToken=3c2e0c2def562052
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/DataInteroperabilityComponent.DLL
Assembly Full Name: Trimble.VCE.Data.IFC, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.IFC.DLL
Assembly Full Name: IFCExport.Interop, Version=1.0.10.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/IFCExport.Interop.DLL
Assembly Full Name: Trimble.Technology.TrimBim, Version=2.28.2.0, Culture=neutral, PublicKeyToken=93c0f7e4f1ca9619
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Technology.TrimBim.DLL
Assembly Full Name: Trimble.Vce.Data.ReceiverRaw, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ReceiverRaw.DLL
Assembly Full Name: Trimble.Vce.Data.JobXML, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.JobXML.DLL
Assembly Full Name: Trimble.Vce.Data.RXL, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.RXL.DLL
Assembly Full Name: Trimble.Sdk.RawData, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.RawData.DLL
Assembly Full Name: Trimble.Vce.Data.ScJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ScJob.DLL
Assembly Full Name: Trimble.Vce.Data.FieldBookJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.FieldBookJob.DLL
Assembly Full Name: Trimble.Vce.Data.MercuryJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.MercuryJob.DLL
Assembly Full Name: Trimble.Vce.Data.TDS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TDS.DLL
Assembly Full Name: Trimble.Vce.Data.SpJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SpJob.DLL
Assembly Full Name: Trimble.Vce.Data.TDE, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TDE.DLL
Assembly Full Name: Trimble.Vce.Data.NGSDataSheet, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.NGSDataSheet.DLL
Assembly Full Name: Trimble.Vce.Data.DC, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DC.DLL
Assembly Full Name: Trimble.Vce.Data.Custom, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Custom.DLL
Assembly Full Name: TA_SwigDbMgd, Version=22.2.0.0, Culture=neutral, PublicKeyToken=fbe3dc80c9fe0828
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TA_SwigDbMgd.DLL
Assembly Full Name: Trimble.Sdk.SurveyCAD, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.SurveyCAD.DLL
Assembly Full Name: Trimble.Sdk.GNSSData, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.GNSSData.DLL
Assembly Full Name: Trimble.Sdk.Features, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Features.DLL
Assembly Full Name: Trimble.Sdk.FeatureDefinitions, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.FeatureDefinitions.DLL
Assembly Full Name: Trimble.Vce.Data.TTM, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TTM.DLL
Assembly Full Name: Trimble.Vce.Data.Moss, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Moss.DLL
Assembly Full Name: Trimble.Vce.Data.SCSResults, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SCSResults.DLL
Assembly Full Name: Trimble.SPJLib, Version=1.43.21400.77, Culture=neutral, PublicKeyToken=36d9a2a67ff4b07d
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.SPJLib.DLL
Assembly Full Name: Trimble.HCC.TBC.Intefaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=0c98c1339e2d36f4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.HCC.TBC.Intefaces.DLL
Assembly Full Name: Trimble.HCC.TBC.NoteLib, Version=1.0.0.0, Culture=neutral, PublicKeyToken=0c98c1339e2d36f4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.HCC.TBC.NoteLib.DLL
Assembly Full Name: Trimble.Vce.Data.M5, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.M5.DLL
Assembly Full Name: Trimble.Vce.Data.OPUSSolution, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.OPUSSolution.DLL
Assembly Full Name: Trimble.Vce.Data.RTXSolution, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.RTXSolution.DLL
Assembly Full Name: Trimble.Vce.Data.Zip, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Zip.DLL
Assembly Full Name: Trimble.Vce.Data.GeneralSurvey, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GeneralSurvey.DLL
Assembly Full Name: Trimble.Vce.Data.GeoRefImage, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GeoRefImage.DLL
Assembly Full Name: Trimble.Vce.Data.KOF, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.KOF.DLL
Assembly Full Name: Trimble.Vce.Data.SBG, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Sbg.DLL
Assembly Full Name: Trimble.Vce.ISTRAMimporter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ISTRAMimporter.DLL
Assembly Full Name: Trimble.Vce.Data.FXL, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.FXL.DLL
Assembly Full Name: Trimble.Vce.Data.Ashtech, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Ashtech.DLL
Assembly Full Name: Trimble.Vce.Data.AshtechJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.AshtechJob.DLL
Assembly Full Name: Trimble.Vce.Data.Skp, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Skp.DLL
Assembly Full Name: Trimble.Vce.Data.Novapoint, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Novapoint.DLL
Assembly Full Name: Trimble.Vce.Data.VCL, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.VCL.DLL
Assembly Full Name: Trimble.Vce.Data.IModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.IModel.DLL
Assembly Full Name: Bentley.DesignSync.Interfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=9bfed12b64a9b7df
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.DesignSync.Interfaces.DLL
Assembly Full Name: Trimble.Vis.Tools, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.Tools.DLL
Assembly Full Name: Trimble.Vce.Data.ImageProcessing, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ImageProcessing.DLL
Assembly Full Name: Trimble.Vce.Data.PythonImporter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.PythonImporter.DLL
Assembly Full Name: Trimble.Vce.Data.UASMaster, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.UASMaster.DLL
Assembly Full Name: Trimble.Vce.Data.SSF, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SSF.DLL
Assembly Full Name: Microsoft.Practices.Prism.Mvvm, Version=1.1.1.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.Prism.Mvvm.DLL
Assembly Full Name: System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.dll
Assembly Full Name: System.ObjectModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ObjectModel/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ObjectModel.dll
Assembly Full Name: EntityFramework, Version=6.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/EntityFramework.DLL
Assembly Full Name: log4net, Version=2.0.12.0, Culture=neutral, PublicKeyToken=669e0ddf0bb1aa2a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/log4net.DLL
Assembly Full Name: Mxips.NET, Version=2.1.8167.30381, Culture=neutral, PublicKeyToken=e789022f6ecb484d
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Mxips.NET.DLL
Assembly Full Name: TISProcess.Net, Version=3.2.0.3518, Culture=neutral, PublicKeyToken=2afac910f877cde3
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TISProcess.Net.DLL
Assembly Full Name: NTJV.Data.Converter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/NTJV.Data.Converter.DLL
Assembly Full Name: Trimble.Vce.Data.TXL, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TXL.DLL
Assembly Full Name: Trimble.Vce.Data.DJI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DJI.DLL
Assembly Full Name: Trimble.Sdk.Scanning, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Scanning.DLL
Assembly Full Name: Trimble.MonSol.ClientLib, Version=1.10.0.0, Culture=neutral, PublicKeyToken=76a11225be98aa56
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.MonSol.ClientLib.DLL
Assembly Full Name: Trimble.Vce.Services.Tunneling, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Tunneling.DLL
Assembly Full Name: Anonymously Hosted DynamicMethods Assembly, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name: System.Diagnostics.DiagnosticSource, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Diagnostics.DiagnosticSource.DLL
Assembly Full Name: System.ComponentModel.Composition, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.Composition/v4.0_4.0.0.0__b77a5c561934e089/System.ComponentModel.Composition.dll
Assembly Full Name: Sdm.NET, Version=3.2.0.3518, Culture=neutral, PublicKeyToken=fa7d95db1187f161
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Sdm.NET.DLL
Assembly Full Name: CsdManagementWrapper, Version=3.6.0.1, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/CsdManagementWrapper.DLL
Assembly Full Name: GeodeticXWrapper, Version=3.6.0.1, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/GeodeticXWrapper.DLL
Assembly Full Name: Trimble.Sdk.Math, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Math.DLL
Assembly Full Name: Trimble.CoreX.Gdtic, Version=4.60.92.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.CoreX.Gdtic.DLL
Assembly Full Name: Trimble.Sdk.Geodetic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Geodetic.DLL
Assembly Full Name: Trimble.Sdk.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Reports.DLL
Assembly Full Name: System.ComponentModel.DataAnnotations, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll
Assembly Full Name: Trimble.Sdk.Results, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Results.DLL
Assembly Full Name: Roc.Common.Symphony, Version=5.0.0.1, Culture=neutral, PublicKeyToken=205c53175e304905
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Roc.Common.Symphony.DLL
Assembly Full Name: Infragistics4.Win.UltraWinTabbedMdi.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTabbedMdi.v20.1.DLL
Assembly Full Name: Microsoft.WindowsAPICodePack.Shell, Version=1.1.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.WindowsAPICodePack.Shell.DLL
Assembly Full Name: Infragistics4.Win.UltraWinStatusBar.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinStatusBar.v20.1.DLL
Assembly Full Name: Microsoft.WindowsAPICodePack, Version=1.1.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.WindowsAPICodePack.DLL
Assembly Full Name: Infragistics4.Win.UltraWinExplorerBar.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinExplorerBar.v20.1.DLL
Assembly Full Name: System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
Assembly Full Name: Microsoft.Practices.EnterpriseLibrary.Common, Version=6.0.0.0, Culture=neutral, PublicKeyToken=9d493c709b8014cc
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.EnterpriseLibrary.Common.DLL
Assembly Full Name: System.Resources.ResourceManager, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Resources.ResourceManager/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Resources.ResourceManager.dll
Assembly Full Name: Microsoft.Extensions.Configuration.Binder, Version=5.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Configuration.Binder.DLL
Assembly Full Name: Trimble.Vce.Share, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.UIManager.dll
Assembly Full Name: Trimble.Vce.ReportEngine, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ReportEngine.DLL
Assembly Full Name: Microsoft.ReportViewer.WinForms, Version=15.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.ReportViewer.WinForms.DLL
Assembly Full Name: BellbirdInterfaces, Version=1.1.6680.18676, Culture=neutral, PublicKeyToken=e46c466c63fb6536
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/BellbirdInterfaces.DLL
Assembly Full Name: System.IO.Compression, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.dll
Assembly Full Name: Trimble.Vce.UI.PPCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.PPCommands.DLL
Assembly Full Name: Trimble.Vce.UI.Wrapper, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Wrapper.DLL
Assembly Full Name: Trimble.Vce.UI.ScsCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScsCommands.DLL
Assembly Full Name: Trimble.SCS_WorkOrder, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.SCS_WorkOrder.DLL
Assembly Full Name: Trimble.Vce.UI.Features, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Features.DLL
Assembly Full Name: Trimble.Vce.UI.GNSS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.GNSS.DLL
Assembly Full Name: Trimble.Vce.UI.SCS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.SCS.DLL
Assembly Full Name: NTJV.UI.CracksControl, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/NTJV.UI.CracksControl.DLL
Assembly Full Name: Trimble.Vce.UI.Monitoring, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Monitoring.DLL
Assembly Full Name: Trimble.Vce.UI.MobileMappingCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.MobileMappingCommands.DLL
Assembly Full Name: Trimble.Vce.UI.INetDownload, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.INetDownload.DLL
Assembly Full Name: Trimble.Vce.UI.CoreCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.CoreCommands.DLL
Assembly Full Name: Trimble.Vis.UI.TccCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.TccCommands.DLL
Assembly Full Name: Trimble.Vis.UI.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.Core.DLL
Assembly Full Name: Trimble.Vis.UI.PdfCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.PdfCommands.DLL
Assembly Full Name: Takeoff.UI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.UI.DLL
Assembly Full Name: Takeoff.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.Reports.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.BaseCommands.dll
Assembly Full Name: Microsoft.Scripting, Version=1.3.0.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Scripting.DLL
Assembly Full Name: IronPython, Version=2.7.11.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/IronPython.DLL
Assembly Full Name: Microsoft.Dynamic, Version=1.3.0.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Dynamic.DLL
Assembly Full Name: IronPython.Modules, Version=2.7.11.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/IronPython.Modules.DLL
Assembly Full Name: Trimble.Sdk.COGO, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.COGO.DLL
Assembly Full Name: System.ServiceModel.Discovery, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Discovery/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Discovery.dll
Assembly Full Name: Trimble.MonSol.HttpApiClient, Version=1.13.0.0, Culture=neutral, PublicKeyToken=76a11225be98aa56
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.MonSol.HttpApiClient.DLL
Assembly Full Name: AutoMapper, Version=9.0.0.0, Culture=neutral, PublicKeyToken=be96cd2c38ef1005
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/AutoMapper.DLL
Assembly Full Name: Microsoft.Extensions.ObjectPool, Version=2.2.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.ObjectPool.DLL
Assembly Full Name: System.Buffers, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Buffers.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.PPCommands.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.INetDownload.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionCommands.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScsCommands.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.CoreCommands.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Features.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.TccCommands.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScanningCommands.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.UI.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.MobileMappingCommands.dll
Assembly Full Name: Infragistics4.Win.SupportDialogs.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.SupportDialogs.v20.1.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Client.dll
Assembly Full Name: Trimble.Vce.Services.WeoGeo, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.WeoGeo.DLL
Assembly Full Name: Trimble.Vce.Services.Bentley, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Bentley.DLL
Assembly Full Name: Trimble.IS.IPPxGate, Version=6.1.0.0, Culture=neutral, PublicKeyToken=62f2fc89c40229e7
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.IS.IPPxGate.DLL
Assembly Full Name: System.ServiceModel.Channels, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Channels/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Channels.dll
Assembly Full Name: System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Web/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll
Assembly Full Name: Infragistics4.Win.UltraWinSchedule.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinSchedule.v20.1.DLL
Assembly Full Name: PresentationFramework.Aero2, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
Assembly Full Name: PresentationFramework-SystemXmlLinq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
Assembly Full Name: PresentationFramework-SystemXml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
Assembly Full Name: Infragistics4.Win.UltraWinDataSource.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinDataSource.v20.1.DLL
Assembly Full Name: Infragistics4.Win.UltraWinTabControl.v20.1, Version=20.1.20201.42, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTabControl.v20.1.DLL
Assembly Full Name: Trimble.WPD.Combined, Version=1.0.0.0, Culture=neutral, PublicKeyToken=e3cd747afe5c1369
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.WPD.Combined.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.DeviceIo.dll
Assembly Full Name: Trimble.Vce.Data.GeoNav, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Geonav.DLL
Assembly Full Name: PresentationFramework-SystemData, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
Assembly Full Name: System.IO.Packaging, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.IO.Packaging.DLL
Assembly Full Name: Trimble.Sdk.Units.resources, Version=1.0.0.0, Culture=pt, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/pt/Trimble.Sdk.Units.resources.DLL
Assembly Full Name: System.Data.DataSetExtensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.DataSetExtensions/v4.0_4.0.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
Assembly Full Name: Trimble.Vce.InSphere.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.InSphere.Reports.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionReports.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.GNSS.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.Reports.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Reports.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Wrapper.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Construction.dll
Assembly Full Name: hoops2620_cs141, Version=26.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/hoops2620_cs141.DLL
Assembly Full Name: System.Management, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Assembly Full Name: Trimble.Vce.GE.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Hoops.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Hoops.dll
Assembly Full Name: WSegmentationManager_x64, Version=0.0.0.0, Culture=neutral, PublicKeyToken=c8536b94f39c562b
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/WSegmentationManager_x64.DLL
Assembly Full Name: MXDBInterfaces, Version=1.3.8161.29018, Culture=neutral, PublicKeyToken=e327e06aede7d772
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/MXDBInterfaces.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/NTJV.Data.Converter.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.IFC.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Machine.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DC.dll
Assembly Full Name: Microsoft.GeneratedCode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name: Trimble.Vce.Data.Custom.NEE, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Custom.NEE.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Custom.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DWG.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TTM.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.M5.dll
Assembly Full Name: Trimble.Vce.Compression, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Compression.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Zip.dll
Assembly Full Name: System.IO.FileSystem.AccessControl, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.IO.FileSystem.AccessControl.DLL
Assembly Full Name: System.Security.AccessControl, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Security.AccessControl.DLL
Assembly Full Name: System.Security.Principal.Windows, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Security.Principal.Windows.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.PropertyGrid.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.JobXML.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ComputationEngine2.dll
Assembly Full Name: System.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
Assembly Full Name: System.Data.SqlXml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.SqlXml/v4.0_4.0.0.0__b77a5c561934e089/System.Data.SqlXml.dll
Assembly Full Name: TBCWebApi.Client.Shared, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TBCWebApi.Client.Shared.DLL
Assembly Full Name: System.Transactions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
Assembly Full Name: System.EnterpriseServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
Assembly Full Name: System.Runtime.DurableInstancing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.DurableInstancing/v4.0_4.0.0.0__31bf3856ad364e35/System.Runtime.DurableInstancing.dll
Assembly Full Name: System.Web.Services, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
Assembly Full Name: System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
Assembly Full Name: System.Web.ApplicationServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.ApplicationServices/v4.0_4.0.0.0__31bf3856ad364e35/System.Web.ApplicationServices.dll
Assembly Full Name: System.DirectoryServices.Protocols, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.DirectoryServices.Protocols/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.DirectoryServices.Protocols.dll
Assembly Full Name: System.DirectoryServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.DirectoryServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.DirectoryServices.dll
Assembly Full Name: Microsoft.Build.Framework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.Build.Framework/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.Build.Framework.dll
Assembly Full Name: TBCWebApi.Basic.Shared, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TBCWebApi.Basic.Shared.DLL
Assembly Full Name: Trimble.Tdx, Version=3.2.0.3518, Culture=neutral, PublicKeyToken=fa7d95db1187f161
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Tdx.DLL
Assembly Full Name: Sdo.NET, Version=3.2.0.3518, Culture=neutral, PublicKeyToken=fa7d95db1187f161
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Sdo.NET.DLL
Assembly Full Name: System.Drawing.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll
Assembly Full Name: Tekla.Common.Geometry.Primitives, Version=4.5.0.0, Culture=neutral, PublicKeyToken=93c0f7e4f1ca9619
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Tekla.Common.Geometry.Primitives.DLL
Assembly Full Name: FlatBuffers, Version=1.12.0.0, Culture=neutral, PublicKeyToken=93c0f7e4f1ca9619
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/FlatBuffers.DLL
Assembly Full Name: Tekla.Common.Geometry.Shapes, Version=4.6.2.0, Culture=neutral, PublicKeyToken=93c0f7e4f1ca9619
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Tekla.Common.Geometry.Shapes.DLL
Assembly Full Name: Bentley.Geometry.2.0, Version=2.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.Geometry.2.0.DLL
Assembly Full Name: Bentley.ECExchange, Version=1.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.ECExchange.DLL
Assembly Full Name: Bentley.Exceptions, Version=1.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.Exceptions.DLL
Assembly Full Name: Bentley.ECSystem.2.0, Version=2.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.ECSystem.2.0.DLL
Assembly Full Name: Bentley.Platform, Version=1.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.Platform.DLL
Assembly Full Name: Bentley.ECObjects.2.0, Version=2.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.ECObjects.2.0.DLL
Assembly Full Name: Bentley.UI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.UI.DLL
Assembly Full Name: Bentley.Units, Version=1.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.Units.DLL
Assembly Full Name: Bentley.EC.Persistence.2.0, Version=2.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.EC.Persistence.2.0.DLL
Assembly Full Name: Bentley.logging-2.0, Version=2.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.logging-2.0.DLL
Assembly Full Name: Trimble.Vce.ParallelComputer, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ParallelComputer.DLL
Assembly Full Name: SharpDX, Version=4.2.0.0, Culture=neutral, PublicKeyToken=b4dcf0f35e5521f1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/SharpDX.DLL
Assembly Full Name: Microsoft.Practices.Prism.SharedInterfaces, Version=1.1.1.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.Prism.SharedInterfaces.DLL
Assembly Full Name: System.Threading.Tasks, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Threading.Tasks/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Threading.Tasks.dll
Assembly Full Name: System.Configuration.Install, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration.Install/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll
Assembly Full Name: Microsoft.ReportViewer.Common, Version=15.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.ReportViewer.Common.DLL
Assembly Full Name: Microsoft.ReportViewer.ProcessingObjectModel, Version=15.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.ReportViewer.ProcessingObjectModel.DLL
Assembly Full Name: Microsoft.ReportViewer.DataVisualization, Version=15.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.ReportViewer.DataVisualization.DLL
Assembly Full Name: Microsoft.SqlServer.Types, Version=14.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.SqlServer.Types.DLL
Assembly Full Name: System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Extensions/v4.0_4.0.0.0__31bf3856ad364e35/System.Web.Extensions.dll
Assembly Full Name: System.Data.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Data.Linq.dll
Assembly Full Name: System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Activation/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Activation.dll
Assembly Full Name: System.Xaml.Hosting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml.Hosting/v4.0_4.0.0.0__31bf3856ad364e35/System.Xaml.Hosting.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ReceiverRaw.dll
Assembly Full Name: Trimble.Vce.Data.EpochScanner, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.EpochScanner.DLL
Assembly Full Name: Trimble.Vce.Data.ProcessorWrapper, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ProcessorWrapper.DLL
Assembly Full Name: Trimble.Vce.Data.GNSSProcessor, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GNSSProcessor.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.dll
Assembly Full Name: System.IO.Compression.FileSystem, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression.FileSystem/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.FileSystem.dll
Assembly Full Name: ChilkatDotNet48, Version=9.5.0.87, Culture=neutral, PublicKeyToken=eb5fc1fc52ef09bd
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/ChilkatDotNet48.DLL
Assembly Full Name: Microsoft.CSharp, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
Assembly Full Name: System.Dynamic, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Dynamic/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Dynamic.dll
Assembly Full Name: Trimble.Licensing.Portable, Version=2.26.87.0, Culture=neutral, PublicKeyToken=b7f8a478d680afaf
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Licensing.Portable.DLL
Assembly Full Name: Trimble.Vce.NetworkAdjustment, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.NetworkAdjustment.DLL
Assembly Full Name: Trimble.Vce.NetworkAdjustment.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.NetworkAdjustment.Core.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.NetworkAdjustment.dll
Assembly Full Name: System.Xml.Xsl.CompiledQuery.1, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name: System.Xml.Xsl.CompiledQuery.2, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name: ISymWrapper, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/ISymWrapper/v4.0_4.0.0.0__b03f5f7f11d50a3a/ISymWrapper.dll
Assembly Full Name: Trimble.Vce.Data.Trajectory, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Trajectory.DLL
Assembly Full Name: Trimble.Vce.Data.GPSeismic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GPSeismic.DLL
Assembly Full Name: Trimble.Vce.Data.Genio, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Genio.DLL
Assembly Full Name: Trimble.Vce.Data.SDMS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SDMS.DLL
Assembly Full Name: Trimble.Vce.Data.BlueBook, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Bluebook.DLL
Assembly Full Name: Trimble.Vce.Data.TMF, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TMF.DLL
Assembly Full Name: Trimble.Vce.Data.SenseFly, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SenseFly.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SDE.dll
Assembly Full Name: Trimble.Sdk.OData, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.OData.DLL
Assembly Full Name: Microsoft.Data.Services.Client, Version=5.8.4.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Data.Services.Client.DLL
Assembly Full Name: Microsoft.Data.Edm, Version=5.8.4.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Data.Edm.DLL
Assembly Full Name: Microsoft.Data.OData, Version=5.8.4.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Data.OData.DLL
Assembly Full Name: System.Spatial, Version=5.8.4.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Spatial.DLL
Ismael Koch
