Inside the template editor have a look at the Options at the bottom of the window.
Save your template as XML-file.
If you insert a new definition into your corridor select "from file definition"
(It might not work if you import a XML created in a newer TBC version into an older version. The old TBC version might not understand all the instructions.)
