i have noticed a bunch of times that tbc does not always generate surfaces correctly. from what i see, it looks like some breaklines get ignored sometimes and from the example bellow it is sometimes halfway through a breakline where the surface crosses the break or ignores it. the red arrows show error sections. in the lower right, i had started fixing this little ditch. but the bottom was totally missing and criscrossing everywhich way.
i had created the surface using linework and points from an fxl file and box selected the whole project. after that i corrected a couple lines, and trimmed the surface edge, but not anywhere close to this area.
bellow is the correct surface
i have seen this several times before using previous versions and other computers. currently i am on 5.70. it is hard to spot unless you really look close. to clean this one up, i again box selected everything and added all the members again to the surface.
ian bissonnette
