Hello Evelina,
Attached is VCL project file (zipped) and my FXL file (zipped) which I used to create line from the discrete points (5724 points) using Process Feature Codes command.
I also attached the CSV file from which I imported all points to the project.
Then, I created new points at 50m interval on the whole line using ANZ Toolbox command Create Point Chainage with 0m offset.
And on these points (with 50m interval) I wanted to use the below mentioned symbol (ST).
Based on idea from Brett of geospatial support, I reversed the line direction using ANZ Toolbox command Reverse Lines (in fact – 1 line), but nothing changed.
NOTE for ANZ Toolbox commands:
When there are many points in the project (like in my case – nearly 5800 points and I will even have more in the future, well above 10 000 points)
and if I use an ANZ Toolbox command, it takes some time till the process is finished (let say 15-20 seconds). And it seems during that time
that nothing happens in TBC (just no command is accessible, the commands will become again accessible after the choosen ANZ command is finished).
So, it would be great to implement a progress bar or an indicator for such cases (for ANZ Toolbox commands) that some happens in TBC,
otherwise it looks as if TBC was/is frozen.
This is my tip how to improve the ANZ Toolbox commands behavior in TBC.
Another tip – TBC is quite slow when it imports/exports many 1000 points. It would be great to speed up these functions (import/export of many 1000 of points).
Martin
Martin Kalafut
Sent: 01-05-2023 01:43
Subject: TBC v5.81 - CAD Point Symbols skewed
Hi Martin,
I am not able to reproduce the issue on my end. Could you please share your project?
Regards,
Evelina
Evelina Indilaite-Gale
