TBC volume calculate method request
  • 1.  TBC volume calculate method request
    Posted 03-27-2023 02:18
    Now I'm using TBC to calculate the volume from my drone data.
    I want to calculate a surface vs a point cloud, but I can't, because TBC can be calculated only as a surface vs a surface. So I create a surface with a point cloud every time.
    It is so troublesome for me because the data of a point cloud is so heavy...
    If anyone calculates the volume with TBC, please tell me your method.
    Or if you have the same problem, please send me a message.
    Nao NAKAMURA
    Sitech JAPAN
  • 2.  RE: TBC volume calculate method request
    Posted 03-27-2023 05:51
    If you spatially sample your point cloud prior to making a surface from it, you'll have a lighter surface.  I have to spatially sample all point clouds in TBC before making surfaces if I ever need to import those surfaces or Recap exports to C3D because it will choke on a large point cloud or a surface (LandXML) created from a large point cloud.
    Hope this helps.
    Brian Christy
    CAD, Layout, and Special Projects
    brianc@customconcrete.com
    O: 317.399.2290
    customconcrete.com
  • 3.  RE: TBC volume calculate method request
    Posted 03-27-2023 06:04
    @奈生 中村
    You can draw a polyline (easier in plan view), either from the command line, or from the CAD tab, to make a boundary for your surface.  This is an effective way to thin out unnecessary data from your point cloud.
    For example, if I have several stockpiles in one point cloud, I create a separate surface for each of them by:
    1. Selecting only that part of the point cloud.
    2. Then create a new point cloud region called "Area 1" or whatever you need.
    3. Spatially sample only that "Area 1" region with all others turned off.
      1. You can define how tightly you spatially sample the region (aka every 2 feet)
    4. Then make a surface from only that spatially sampled region.
    5. Next draw your polyline (in plan view) around your area or whatever topography with which you're working.
    6. Then add that polyline as a surface boundary for your new surface.
    7. This is the best way I've found to get lighter local surface data from a specific area, from a large point cloud.
    If you need to get your surface into something else, like Civil 3D, you can export the point cloud region as a Recap project and drag-n-drop it into C3D.  You can also export your newly created surface as a LandXML file (Export => Construction Tab).  C3D has a command to import a LandXML.
    Brian C
  • 4.  RE: TBC volume calculate method request
    Posted 04-02-2023 22:38
    Thanks, Brian-san
    I understand your information.
    However, I already know I need to create the boundary, and I feel it is troublesome.
    If you know a convenient way of creating, please let me know.
    Thanks
    Nao
    Nao NAKAMURA
    Sitech JAPAN
  • 5.  RE: TBC volume calculate method request
    Posted 04-04-2023 10:24
    Nao,
    There was a recent TBC Power Hour titled "Working with Surfaces & Contours" that I believe you will find helpful.  We have had similar challenges in trying to manage drone generated TTM or point cloud files that exceeded our computers capacity, and this demonstrated a lot of helpful techniques to solve those problems.  Here is a link to that library.  Hopefully this helps.
    Upcoming and On-Demand Webinars | Trimble Geospatial
    Anthony Dalla
