Hey Chad,
Thank you for responding.
This is the box that you end up having to use with WM in TBC. I don't understand the organization of how they show the order or the WOs. I end up having to sort them each time and you only have that tiny window to find your WO you want to import. On top of that, if you want to switch to another data collector, it has to load again because it's online, If you close that window by accident, it has to load again because it's all online.
This is the old pop-up box that you used to have to import WOs into TBC via the old way when you could download locally to your computer. The nice thing with it, was that you saw everything that you had downloaded and could flip back and forth between collectors really easily to see what was on them/import. The only real grievance that I had with it was that when you adjusted the size of the window, it would revert back to this roughly 3.5"x3.5" box every time.
I just played with the old Office Synchronizer for a minute and changed the TCC settings in it (removed the workgroup folder name since WM doesn't support workgroups atm), and synched it down to my computer. Then it goes to my Trimble Synchronizer Data folder on my PC, which I can then import the old way if the job is also connected the old way. So a temporary workaround fix I guess you could say that at least gives you the option to work offline.
While processing a couple weeks worth of data the other day, and wanting to work in the order of as-built type (material, etc.), I ended up going to each data collector through the project in the WM browser, highlighting the WOs in batches (as it would only copy what was visible in the window, not everything you highlighted and scrolled out of view) and pasting it in Excel, then moveing the modified date for each WO to the column beside it (it wouldn't paste side by side in columns, just one after the other), and then colour coding from there. I actually liked having it in Excel better as then you can save it and add notes and still read the WO name. Whereas my old screen snip and strikeout method worked for the immediate moment, but doesn't help you when you're looking for something two years down the road.
Thank you, again!
Katie
Katie Byron
Sent: 05-19-2023 11:37
Subject: TBC WorksManager Work Order Import Feature Request
Hi Katie,
Thank you for these suggestions.
I want to make sure that I am understanding number 2. Is this a pop box you are seeing in WorksManager, or on the data collector in SiteWorks?
Thank you,
Chad
Chad Haschen
