I have a workflow that I have successfully used for a number of years, but I am now seeing a recurring issue since TBC2024... I wondered if anyone else has experienced the same?
When defining a site to be stripped, I define the strata, enter borehole information and create the various depth surfaces. If I have areas that are to be then excluded from the soil stripping, I create these boundaries, plus a larger external boundary that encompases the entire site area. I then select the external boundary, set it to strip the uppermost stratum, and the internal boundaries can be set at 0mm (or whatever is requried).
Historically, this has worked perfectly every time, however what I now find is that this workflow works initially, but then if the surfaces are rebuilt, the external boundary essentially brings the OG with Topsoil Stripped surface down in elevation (for example lowering by 100m or so).
To resolve this, I have to remove the external boundary, re-build the surfaces, and re-apply "strip uppermost stratum" to the external boundary and re-build the surfaces again.
Stevie McCafferty
