Template versus Surface
  • 1.  Template versus Surface
    Posted 09-06-2022 23:28
      |   view attached
    I have this strange issue.
    I have created a Corridor Template.
    In the two highlighted segments above, when I use the slider bar, I see that the Offset width varies. I could not find a reason for the same.
    I have attached the *.vce file as a Zip file.
    Could some one help me.
    Thanks.
    Saif Bin Darwish
    Attachment(s)
    zip
    AVB-01A.zip   2.36 MB 1 version
  • 2.  RE: Template versus Surface
    Posted 09-07-2022 07:10
    Edited by Erik Petersen 09-07-2022 07:11
    All of them are staying consistent on my end Saif. However the first 3>4 is showing a positive 2% on your screen shot on the file provided its -2%
    There is also on one template in the file provided you have three
    Erik Petersen
  • 3.  RE: Template versus Surface
    Posted 09-07-2022 21:50
    I figured out what was going wrong.
    I had created additional templates further ahead in the chainage and the segment was transitioning in width to the next template.
    I corrected by creating additional templates which were copies of the previous template just a meter before the new template. This fixed the issue.
    Thanks for all help.
    If there is an easier and more robust work-around, do please let me know.
    The information transmitted through this mail is confidential and may be legally privileged. Access to this mail other than the intended recipient is unauthorized. If you are not the intended recipient, please notify us or erase contents. Any re-transmission, dissemination, action or omission based on the content of this mail by persons other than the intended recipient may be unlawful and strictly prohibited. We monitor email communications through our network. Any violation for the above norms may lead to prosecution.
  • 4.  RE: Template versus Surface
    Posted 09-08-2022 00:34
    Those auto-connecting nodes can be annoying and dangerous. Run into that a long time ago.
    See here for the old thread
    "corrupted" TBC file - any way to extract information or load anyway? | Trimble Business Center
    Alan Sharp explains in number 8 how that works and suggests to add a Null/empty template before the next section. That will prevent the nodes in different templates to auto-connect.
    Have been doing that ever since. Haven't done corridor modelling in a while, don't know if the feature request Alan mentions has been implemented in any way.
  • 5.  RE: Template versus Surface
    Posted 09-08-2022 00:49
    That was great. Thanks.
    I have never used a "Null" Template. I will check this out.
    The video that Alan refers to is not there (Link not working, shows Error 404). Any way I can access this video. Would be of great help next time.
    Thank you very much.
  • 6.  RE: Template versus Surface
    Posted 10-03-2022 12:02
    A blank template works well for certain things, but quite often you need to define a transition distance where the node begins to transition.
    You can also uncheck the box to disallow transitions in that instruction:
    Nelson Hays
  • 7.  RE: Template versus Surface
    Posted 10-03-2022 21:48
    Thanks
  • 8.  RE: Template versus Surface
    Posted 09-08-2022 08:28
    Sometimes it can be helpful to "bookend" sections, to make sure you control what is going on in-between and to manage the frustrating node connections. Instead of copying a template, consider using a reference template for this purpose. This will allow edits to more easily propagate.
    Dave Olander
