I was a heavy trimble user a couple of years ago, but now work in a metrology role with Leica gear and specialised software package. So I don't have the kit or TBC license to test this :-( I do have budget to hire gear for testing, but want to know if something is at least plausible before trying. I know this isn't necessarily strictly a TBC question, and could be an Access or Siteworks issue, but felt the data will end up in TBC one way or another so this is a good place to start :-)
I wish to track the realtime roll of a ship with 2 total stations tracking 2 prisms mounted equal distance from ship centreline port and starboard. The total stations would be onshore 100-200m away. My idea is that, using the change in height between two prisms, the roll value can be computed.
One major problem however is, in order for the change in height values to be accurate, I need to time-align the observations exactly. Just pressing measure on two dataloggers at the "same time" isn't going to cut it. Ideally, I want to keep the total error budget for prism height values <5mm. And even on a calm day, the ship will be moving more than that every second or so. As part of this test, I wish to use RTK GPS as well (although my expectation is 15-40mm error in heights will make GPS alone unsuitable for the task).
So, my first thought. Run Access in Integrated survey mode. Setup total station to continuously measure the prism. Switch to GPS, enable continuous measurement. Repeat for 2nd pair of prism and GPS. When the two separate jobs are dragged back into TBC, the recorded epochs from the GPS datasets could be somehow used to align the data from two data loggers?
Does anyone know if this might be possible? Or perhaps have another idea for a methodology? I
Other random thoughts:
- I have sent this question to Trimble as well and am awaiting an answer - I imagine they might be a while since it is a little strange
- It doesn't even necessarily need to be an integrated survey, I could just drag a raw T02 file from the GPS into the TBC job? But presumably, the total station observations are tagged with whatever the time happens to be set as on the total station or datalogger - not necessarily in sync with GPS time?
- A machine control software suite might be better suited, I see dozers driving around with dual GPS all the time, but not sure if I have seen multiple prisms mounted on the one machine before?
- T4D can connect to multiple instruments, but it isnt really something that can be setup ad-hoc in the field easily (and not sure if it will get sub-second time alignment?)
- My metrology software (Spatial Analyser if anyone is interested) has a synchronised measurement option, and supports real time connection to multiple total stations. In theory it is perfect. In my workshop testing however, the "simultaneous" observations are significantly lagged and not fit for this purpose.
Thank you in advance for any comments,
Damian
The Dude
