TopoDOT export not including geographic info
  • 1.  TopoDOT export not including geographic info
    Posted 05-20-2026 07:40
    After processing trajectories, registering a run and generating scans, when I use the Export to TopoDOT tool the geographic information seems to get lost somewhere. When I import into TopoDOT it appears in the ocean somewhere. Looking at the .txt that accompanies the .las after export, it says that the export unit is meters, but my TBC project is set up for US Survey Feet, NAD83/2011. I don't see an option to set the export unit in the TopoDOT export tool. I do see that option in the .las export panel. I'm running TBC 2025.20
    Paul Keays
  • 2.  RE: TopoDOT export not including geographic info
    Posted 05-20-2026 10:35
    Update: Wasn't an issue with TBC. In TopoDOT under Point Cloud settings you can set the units.
    Paul Keays
