The issue is one of two things. When I get this question, most of the time there is not a closed traverse. in the image below, the traverse was started at point 2 backsighting 1. The traverse was run around and the last angle was set at point 5 (same as 1) and turned to point 6 (same as 2). I usually see people occupy point 4 and turn to 5 and end the survey there. The closing angle is between points 5&6.
The second issue that I see is that if you name a point as 1, it will always be point 1. If you do have a closed traverse, try renaming the closing points to their original names. In my example, I would have named point 5 as point 1, and point 6 as point 2. When asked by the data collector if I wanted to average the points, I would have selected to store as another point.
Kris Fairley
Lead Support - Advanced Technology Group
AllTerra Central
Houston, TX
