Thanks Everyone! It was indeed an update. I had checked for updates thinking it was a patch to TBC, but it is was one of the other updates, After update job file imports correctly.
Ben Doherty
Sent: 04-28-2023 08:09
Subject: Trimble Access 2023 job files not loading in TBC 5.81
Instead of EXPORT, alternatively (within Trimble Access) you can COPY your job to an USB (it creates a .JOB file)
and then import the .JOB file to your TBC project.
It works fine - even better than EXPORT to JXL, since if you use a FXL library,
where you also defined some attributes for the collected point/line/area features
and one of the attributes is PHOTO attribute, EXPORT to JXL does NOT include
the JPG pictures created during data capture in the field and you must manually copy
the associated pictures with the collected features to your PC.
And then - within TBC - you have to assign the pictures to corresponding points/features.
Martin Kalafut
