I want to add a couple of important points to Chris' response.
As Chris has already pointed out, Spectra Origin is an evolutionary extension of Survey Pro. Having recently spoken to the team at software development company (they specialise in survey software development), they confirmed that the transition is indeed worthwhile.
To make the process as smooth as possible, especially with 20 crews, it's important to prepare properly.
- Provide pre-training for your staff
- Start with a pilot project with 1-2 crews
- Discuss training opportunities and discounts with your dealer.
Future prospects are very optimistic:
Enhanced functionality on a new platform, regular Trimble Access updates, improved support for new equipment, deeper integration with other Trimble products
Kristian Karimo
Sent: 05-27-2022 04:59
Subject: Trimble Access and Survey Pro Compatability
Hello Sean,
Unfortunately, as you have discovered, the only way to bring data that had been collected in Survey Pro into Trimble Access / Spectra Origin is to export it as a .jxl and then bring the exported .jxl into either TA or Origin. Spectra Origin is the successor to Survey Pro and is built on the Trimble Access platform. A workflow transition guide can be found attached.
I believe that there may be sales incentives still available to make the transition to Spectra Origin from Survey Pro, but you would need to confirm the current availability of this with your local authorized Trimble / Spectra dealer.
Best Regards,
Chris
Chris Cain
