thank you all it helped me a lot. I just downloaded your zip-file Ronny.
I also tried to usw 7zip and then open the extracted file in notepad++ and extracted the columns manually but I am happy, some of you already did plenty of work.
is there also a smarter way to export all style definitions for, point symbols, linestyles, Points, lines, Layer definitions, Textstyles and hatchstyles/hatches?
My workflow right now is to export a FXL-File and for the Hatches i export a *.pat-File.
Sent: 04-07-2026 18:50
Subject: Trimble FXL XSD Schema
If you open the DLL in Notepad++ it seems you can relative simply just copy/paste it out of there.
From the end of line 6639 to 47681.
I used it as exercise to familiarize myself a bit more with those chatbots.
I threw the copy/paste content from the DLL at it, had it remove illegal characters and split it at each new schema start.
It came up with the following Python script and the attached split up files.
import refrom pathlib import Pathfrom html import unescapeimport zipfile# Load raw texttext = Path("DLL_Dump.txt").read_text(errors="ignore")# Remove invalid XML charactersillegal_xml = re.compile(r'[^\x09\x0A\x0D\x20-\x7E]')text = illegal_xml.sub('', text)# Unescape HTML entities (< > &)text = unescape(text)# Locate embedded XSD schemasschema_re = re.compile( r'(<\?xml\s+version="1\.0"\s+encoding="UTF-8"\s*\?>\s*' r'<xs:schema[\s\S]*?</xs:schema>)', re.IGNORECASE)schemas = schema_re.findall(text)out_dir = Path("schemas_out")out_dir.mkdir(exist_ok=True)name_counts = {}for schema in schemas: # Determine base name from targetNamespace m = re.search(r'targetNamespace\s*=\s*"([^"]+)"', schema) base = m.group(1).rstrip('/#').split('/')[-1] if m else "schema" base = re.sub(r'[^A-Za-z0-9_.-]', '_', base) suffix = "" # Special handling for FXL schemas if base.lower() == "fxl": vm = re.search( r'FXL\s+Schema\s+Definition\s+Version\s*([0-9.]+)', schema, re.IGNORECASE ) if vm: suffix = "_" + vm.group(1).replace('.', '_') # Handle duplicates (only when no version suffix is present) name_counts[base] = name_counts.get(base, 0) + 1 dup = f"_{name_counts[base]}" if name_counts[base] > 1 and not suffix else "" filename = f"{base}{suffix}{dup}.xsd" (out_dir / filename).write_text(schema, encoding="utf-8")# Zip the resultswith zipfile.ZipFile("schemas_fxl_versioned.zip", "w", zipfile.ZIP_DEFLATED) as z: for f in out_dir.iterdir(): z.write(f, f.name)print(f"Extracted {len(schemas)} schemas")
Sent: 04-07-2026 09:47
This takes a bit of work. You can get at them with a string dumper, such as llvm-strings or gcc strings. That's going to get everything with printable strings so you'll have to weed it down... search for the xml header and that will get you the start of each file, contents are within the starting and ending xs:schema element tags. A good text editor will get you to this same point as well.
These aren't string resources in the typical sense of DLL resources (i.e. in the .rsrc section), so a resource extractor won't find them. They are all raw string data in the .text section. I should have been clearer on this in my first post, sorry.
Side note, it would be helpful if Trimble published these like the rest of the schemas (e.g. JobXML, RoadXML, etc). I use them frequently. Not sure how many other folks would find this handy but it doesn't look like I'm the only one.
Andrew Klingenberg
Sent: 04-06-2026 16:43
@Andrew Klingenberg how do I extract those files from the dll? Thanks in advance
Peter Pitser
Sent: 04-06-2026 14:58
Peter,
To my knowledge none of the XSD files for FXL or related schemas have been published. However, all of them are embedded resources in Trimble.Vce.Data.FXL.dll and you can extract them from there. That is how I have been acquiring them.
Andrew Klingenberg
