Hello Sean,
Thank you for the post. I am checking if there was an intentional change made to either the webUI or the background conversion service.
I have just tested and found your statement correct that older job versions will only offer an upgraded job file as the output.
If you then try to convert the upgraded 2022.00 job file you get the option to export jxl.
The two step process may not be ideal but hopefully it is enough to allow you to read the contents.
Chay
Chay Froggatt
