For example, with HCE, you won't be able to open DWG/DXF-files in Version 2018, only V2013 an older will be working.
Titus Emanuel
SITECH Germany, digital engineering services
Sent: 01-22-2024 09:07
Subject: Trimble TBC HCE
Till about 6 years ago, I believe version 4.12 or so, there were 2 TBC versions. Plain TBC focused on geospatial and TBC HCE (Heavy Civil Edition) focused on Earthworks and Civil Design.
With V5.00 both lineups were merged into one product. Meantime we are past version 5.91.
So, if it is an actual HCE version it is rather old, and you might miss some feature. It all depends on what you're planning to do with it.
You might want to check the release notes here Trimble Business Center - Trimble Inc. on what you might be missing out. Unlike the ones for Access the ones for TBC unfortunately never tell the whole story. Not just once we found something that wasn't mentioned in the notes.
