Updating Feature Definition Library Groups
  • 1.  Updating Feature Definition Library Groups
    Posted 02-27-2023 10:00
    Edited by David Kosakowski 02-28-2023 10:12
    Hello everyone,
    I recently updated our point codes in our FDL by adding, removing and editing based on field crew input. All the changes took place directly in each point feature. I have groups set up for our field crews based on the type of work they are doing, but the codes in the groups do not reflect the changes I have made. Is there a way to force these updates into the group or do I have to manually remove each original code and add the updated one? obviously I would need to add any new codes, but edits I figured would be reflected across the entire library.
    [James] [Bronico] [Jr.]
    [Senior Survey Technician]
    [Phillipsburg] [NJ][USA]
