Wow, you guys really came through! I should have known there would be multiple ways to do this in TBC. This is exactly what I needed to get started. I'm sure there's pros and cons to each method, but after experimenting yesterday it appears they all work successfully. My initial follies were as follows: 1, using the drag and drop of the XML file instead of the import command, and 2, attempting to use the generic "explode" command on the imported XML surface. This has revealed a lot of options that I wasn't previously using.
Ben, thanks for the quick contour tool tip! I'll keep that in mind for simplifying overly complicated surfaces.
Thanks again everyone for taking the time to help!
Anthony Dalla
