What is the best way to compare your model to the plan cross sections. I would like to know what the most efficient way is for two scenarios.
- When you have both pdf cross sections and CAD cross sections.
- When you only have pdf cross sections.
I don't currently have the take off module for digitizing pdf cross sections, so I don't know how good it is. I also don't know if you can digitize cross section cad lines as well with the take off module.
I have a corridor that I built, and I am able to create cross sections and plot them all on one sheet in TBC, and would like to create a surface from the cross sections, to then be able to add to my corridor as a reference surface, that way I can check the model I created with the plan line work.
matt fleischman
