v2026.10 no longer allows PTX export in grid. Is this a bug, or intentional?
  • 1.  v2026.10 no longer allows PTX export in grid. Is this a bug, or intentional?
    Posted 4 hours ago
    We still utilize PTX exports both internally (extraction/modelling in other software) and externally (for certain client deliverables).
    After the update to 2026.10, I notice that what used to be the "PTX" export option is now the "PTX Structured Exporter", and there is no way to select Grid as the export scaling:
    We operate and deliver in grid projections with minimal distortion but very large coordinate values, so we will see shifts of tens of feet every time we export.
    This is causing some major problems with both staff and clients, and is forcing us to manually shift clouds after export, which is not ideal.
    I'm no fan of the PTX format, but we never had any problems with it until this most recent update.
    Anyone found a workaround? Is there a project setting I need to change?
    Eric Glaves, PLS
    David Evans and Associates
