After changing the setting it initially fixed the issue, I immediately posted that it worked. Not long after it bugged out and I made note again. Since that day that particular issue has apparently resolved on its own, as i has been closing normally without having to end task.
Note: I believe I upgraded from 5.70 to 5.81 and did not have the intermittent end task before issue, that I can recall. I am fairly new to using TBC and I learned right away TBC was fickle about how you open, save, close projects and then ultimately exit the program. I always try to save, close project and then exit.
Beau
Sent: 12-27-2022 08:38
Subject: Version 5.81 crashing
I've had this issue off and on for some time now but still running 5.70. Have you had any luck on a fix?
Ben Wall
Sent: 12-18-2022 08:15
Hi Ronny,
I tried changing the graphic settings. Still crashing.
I am not using a docking station.
Vic O'Brien
Sent: 12-16-2022 10:31
Changing it from Auto-detect to OpenGL2 worked for that particular issue on my end.
Beau Trahan
Sent: 12-14-2022 14:33
That looks like a graphics driver issue.
Have you tried setting it to another graphics mode, i.e. OpenGL? You'll need to restart TBC after that.
Are you using a docking station? Have you tried without it.
