I assume you know that you can create an Alignment from any Linestring
But you'll need to have the linestring ready with at least a horizontal definition.
For your CSV file you need to have an Alignment with at least the horizontal component ready.
If you have multiple alignments in your project the CSV filename must match the name of the target alignment.
In your CSV file you need to get rid of the Column 1 with the point numbers and the last 2 columns. It must be 3 or 4 columns maximum.
If you have successfully imported your file, you'll end up with "Stored Cross Section Nodes" along the alignment
- select one of them
- right click -> Select Similar
- CAD-Tab -> Explode
- now you have single string lines and points in addition to those cross sections
- select one of the small stringlines
- CAD-Tab -> Join
As long as I know is there no way to combine a given horizontal alignment with another vertical alignment. Or as you asked an imported 2D profile drawing.
So, I did some programming the last few days. The attached macro will do the following:
- lets you combine the horizontal component of one line (Line 1) with the vertical profile of another (Line 2)
- the vertical profile can also be a 2D-Line in Planview, in that case you'll have to define the origin (Chainage 0.0 and Elevation 0.0; Chainage-Axis parallel to Easting and Elevation-Axis parallel to Northing)
- in case the length of Line 1 doesn't match the length of Line 2 you can compute the Scale to stretch/shrink it accordingly
- the vertical scale will work independently of the horizontal scale
- you can also draw the vertical profile to the plan view (with variable scales and direction)
- in either case, if a scale other than 1.0 is applied the macro needs to chord the profile first, otherwise any curvature in the profile would get messed up (you can't simply stretch arcs and splines); it will use the bigger one of the scales to recalculate the chording tolerances
- the resulting line will always be a linestring, just create a new alignment from it
See the attached video for a demonstration.
Unzip the macro ZIP into a folder in "C:\ProgramData\Trimble\MacroCommands" and restart TBC.
