Victor
When comparing two surfaces, and each is above and below the other you will get both cut and fill.
You can cleanup your data or redefine your volume area to more accurately define your volumes.
You may be able to use Surface to Elevation to reduce/eliminate your fills; depending on your data set (flatness).
Tim McCann
