Hi Taylor.
did you find some tutorial or more informaction about it?
I'm looking for more information about PCS900 Concrete Paving and C&G. especifically how this works with the Power Curber 5700-D if that is possible.
We are working with this machine right now , PCS900 already installed "left side mold" and we have some concerns.. described below.
1.- When we start to pour a Curb & Gutter after about 10 or 20 feet.the machine starts to go down into the ground and said that we are 0.30 feet highter. looks like it doesn't follow the line properly.
I'm wondering if we are setting up in a wrong way or we are missing something.
2.- Can i change the mold reference line in the machine? from TBC to EOP?
3.- How to make an automatic transition between catch and spill curb with standard mold installed?
if you know something that can help me i would appreciate it.
Thanks..
have a nice day..!
Dionicio Montero
Sent: 10-01-2019 06:01
Subject: Re: What is needed in a 3D model for a machine control curb machine?
UPDATE:
We ended up purchasing a new Power Curber 5700-C with the machine control capabilities. Setting up the model turned out to be fairly simple. Only one elevated line is needed. For us, we use the top back of curb. Select and horizontally offset that line both left and right to make a surface wider than the machine with 0 vertical offset. Non elevated lines can be used to create the .svl as usual. We have played with it quite a bit and are still working out the kinks.
Thank you to everyone that replied to the original post. It was great to have ideas ready going into the process. Feel free to ask any questions as I know the process I listed above is short and to the point.
