Which version is ? (should have the same version number of TBC example 2024.00) to eliminate confusions
Should also come bundled with the TBC 202x.xx installer file
Hi Alexander,
The newest one I am aware of is right at the bottom of this post: https://community.trimble.com/blogs/vyom-kaushik/2023/08/23/trimble-business-center-utilities-license-and-inst
Hopefully someone from Trimble can confirm that this is the latest and still compatible with latest releases.
Alexander, I went thru this just last week over the phone with my dealer's tech support. The link he directed me to for download is below, the link is at the bottom of the third (3rd) page. If you have tried an install and it crapped out like mine did, run the advanced option and check everything (did not listen to my support and had to do it again after a 2nd failed update/install). When i ran the advanced the install went perfect. Hope this helps.
https://trl.trimble.com/docushare/dsweb/Get/Document-1055627/022516-703B_TrimbleBusinessCenter_Utilities_USL_0524.pdf
Estimado Juan Woodall
Se ejecutó correctamente
Gracias
