I installed TBC v5.40 (no patch).
I created a blank VCE, created 2 linestrings.
I can confirm that Toggle Line Marking now zooms to extents afterwards.
This happens regardless of whether one or none of the linestrings are selected.
Neither v5.40 nor v5.40.1 Release Notes mention Toggle Line Marking.
Marshall - To answer one of your original questions - I can't think of any reason why it should do this.
When reading marking, I'd expect to be zoomed into a specific area of linework, not zoomed out to see the entire site. I would hope that this is an unintentional side effect.
Have you tried the v5.40.1 patch? If the problem is still there, I would definitely submit this as a bug.
Quan Mueller
Revenant Solutions - TML Development
Sent: 03-23-2021 11:28
Subject: Why Does Toggle Line Marking Zoom Extents?
Quan: The "zoom extents" beside the Isolate Layer is not turned on. Yes, this started happening on version 5.4. See attached.
Marshall Cant
Sent: 03-23-2021 11:18
Earlier this year, someone asked on this thread why TBC was doing zoom extents after every command.
Someone else answered to check the "Zoom Extents when the filter changes" button that's next to the "Isolate Layer" button in the View Filter Manager.
That apparently fixed their problem - so maybe it'll fix yours?
Out of curiosity, I've tried to reproduce this behavior (auto-zoom-extents triggering on any command change) in v5.31, and can't.
With both buttons "on" and creating linestrings in the selected layer, it never auto-zoom-extents. Likewise, running Toggle Line Marking on and off, via both the status bar button and from the Command Pane, it never auto-zoom-extents.
Have you had this trouble since you upgraded to v5.40?
Quan Mueller
