They should only be on your hard drive if you download those design or you were the creator.
So, once you select your project and click OK. your should be having a new window open up. You should also, at the same time get those external design option available.
Sent: 05-28-2024 20:05
Subject: WM designs into TBC?
il try again with a blank
below is designs that should show
could those project design also be on your hard drive?
Peter Batson
Sent: 05-28-2024 18:49
using the WORKSMANAGERPROJECT command will get you where you want to go. This example I just opened a new TBC project. All blank. I was logged into the Trimble ID and used the WORKSMANAGERPROJECT command.
Francisco Guerrero
Sent: 05-28-2024 16:32
Hi Francisco, I still cannot get designs to import from WM
The add external and reassign external commands report.
I thought these commands were for job sites pre WM ?
can I download the designs from WM web portal and place them in a folder somewhere where TBC can read them and populate inside TBC?
Peter Batson
Sent: 05-22-2024 17:51
I have had luck doing a copy of the project and the project folder. By renaming, I was able to open the corrupt project. Trimble has a such a command for this need. I haven't heard many people ask for this or mention this command.
be sure to be logged into your Trimble ID. TBC Command > WORKSMANAGERPROJECT< you will then be able to choose your project and import all your WM setting" calibration first, then units, then control points, boundary and so on. You should now have access to your WM account and project. You will have access to external design that you will be able to quickly import if needed.
Francisco Guerrero
