[Workaround] TBC v2026.10 - Legal Description Writer missing the Browse button
  • 1.  [Workaround] TBC v2026.10 - Legal Description Writer missing the Browse button
    Posted 16 hours ago
    Edited by Quan Mueller 15 hours ago
    Problem:
    In TBC v2026.10 I can't open/load an existing legal description template file. I can save a new one and pick it from the recently used list, but I can't load one created from an earlier major version of TBC (v2025.21, etc.).
    Background:
    At the top of the Legal Description Writer command, the first input field is "Template file:"
    In earlier versions of TBC (I checked v2025.21, v2024.13, v5.00.2 (2019)), there are two UI controls:
    • A drop-down list
      • Contains:
        • <Default> (comes shipped w/ TBC)
        • Template file path currently used by project
          • Saved in VCE and template VCT files
        • Recently used template file paths
          • Stored in Options (User.Options file in your roaming AppData)
          • Resets when you delete User.Options
          • Resets when you use a new major version of TBC
          • Can be saved/loaded by exporting/importing ALL options via Options command
    • A "..." browse button to select a template file from disk.
    In TBC v2026.10, the browse button was apparently removed.
    • The term "Legal" does not appear in the 2026.10 Release Notes
    • I did not find a ReadMe file in the installation.
    • I saved the default template for v5.00.2, v2025.21 and v2026.10, and the only change from 5.00.2 to the newer ones are 2 new XML tags (StartJumpToNestedArea and EndJumpToNestedArea). So I don't think it's a template file compatibility issue.
    Workaround:
    Add your desired template file paths to the recently used list.
    1. Create a folder "Legal Description Templates v2026"
    2. Run Legal Description Writer command
      • Leave "Template file:" as <Default>
    3. Click "Edit / Preview" button
    4. In the "Description Template Editor" dialog, click the "Save As" button.
      1. Browse to the folder in Step 1.
      2. Enter the file name of your template file.
      3. Click the "Save" button.
    5. Repeat #4 for each template file you want to add to the list.
      • The folder in Step 1 will have the right file names, but only default content.
    6. Select <Default> for "Template file:"
    7. COPY (do not move) your template files to the folder in Step 1.
      • Now the folder in Step 1 will have the right file names AND the right content.
      • You make copies so that your originals are safe - like if you decide to blow away this folder when a new version of TBC comes out...
    Now you can select your desired templates from the recently used list.
    Call for Interest:
    I can create an extension command (C# macro) for managing the recently used list - if there's enough community interest.
    • Reply to this post, message me, or email quan@revenantsolutions.com with your TBC version and a seat count - to signal your interest.
    • This command would be added to Revenant Core, a base/low-cost module.
    Edit: formatting
    Quan Mueller
    Revenant Solutions | TBC Extension Developer
    Superuser Program | superuser@revenantsolutions.com
