Works Manager Project Boundary
  • 1.  Works Manager Project Boundary
    Posted 10-06-2023 06:44
    Hi
    I seem to be getting a strange issue where the project boundary appears shifted when I adopt from Worksmanager to TBC when using a published coordinate system in WorksManager.
    After drawing in the project boundary, i adopt it into TBC and the boundary is shifted even though i have everything set to the same coordinate system in both TBC & WorksManager.
    However, when I create a dummy model in TBC and export using Machine job Site Exporter using the desired coordinate system in TBC, I use the Cal file to set up a dummy project in WorksManager and only then does the drawn in project boundary successfully adopt back into TBC in the correct position.
    There seems to be an issue when I draw the boundary and adopt to TBC when I use a published coordinate system in Worksmanager! as opposed to throwing in a dummy .cal file created from the same coordinate system in TBC.
    Been scratching my head with this for hours and I can't understand why!
    Richard
    Richard Childs
  • 2.  RE: Works Manager Project Boundary
    Posted 10-18-2023 07:54
    Can't say that I've noticed that issue at all, but then again, my work flow is a bit different. I will typically:
    1. Set up my units, coordinate system, etc. in TBC
    2. Create a new a project in WM with the name I want, skip through all the settings, draw a rough/dirty project boundary
    3. Add the project to TBC and publish all of my settings units, calibration (if using a published coordinate system or don't publish if setting up a site that needs calibrating)
    4. Adopt the project boundary from WM and fine tune it to where I actually want it, then re-publish it.
    Katie Byron
  • 3.  RE: Works Manager Project Boundary
    Posted 10-18-2023 08:05
    Thanks for the reply Katie!
    Richard Childs
