 Add Tunnel Template Position
Panagiotis Vranis's profile image
Panagiotis Vranis posted 06-19-2026 10:59
Hello to all TBC users.
I use this command to add the tunnel's characteristic stations,
meaning the positions of each day or night shift progress,
and especially these of the lattice girders placement, or the HEB support frames.
These stations are not integer numbers or with a regular decimal interval.
The problem is that every time I run this command,
the software re-computes all the 3d meshes created until that, comparing and comparing each designed mesh to the corresponding as built one,
making it very time-consuming, about 6 -12 minutes to add a single template position.
