The title actually says it all. I installed TBC, restarted the machine as instructed, and whenever I try to start TBC I get this error message. I've already repaired, uninstalled, reinstalled the software - nothing helps.What can be the reason?
Hi Tom,
Did you uninstall using the latest Cleanup Utility? Your dealer is the first line of support for technical issues. Have you contacted them also?
David
