 Black Layer Color
Amber Dymond's profile image
Amber Dymond posted 11-07-2024 12:14
1.      Why does the color "black" come up as "white" when chosen to represent text or a site region? I have to mess with the color black on the scale every time in order for it to come up as black. For example, I want my SITE-AOI layer to be the color "Black" - but when I go to put a polyline in, it shows up as the color "White." I then have to go to the Layer Manager, scroll to my SITE-AOI layer, go to the color drop down menu, click on "more colors", and change the scale for the color black just a hair (ie. the color numbers from the scale would now be 18, 18, 18), and then it comes up as black. I have to do this EVERY TIME for anything I want to be the color black. Why doesn't the color "Black" just show up as the color "Black!?"
Because you can switch the background color to black. In that case all black lines would be invisible, so TBC is inverting them. The same for "White". This is handy if you switch the drawing window background color regularly.
But especially for plotting that can be really annoying if you set the text color to white, i.e. for text on top of an image and since the paper is white it changes the text to black. We can't print actual white for instance, everything past 244,244,244 is converted to black.
It can be mitigated to a certain degree by setting alternative layer colors for separate view-filters in the advanced view-filter settings. But this one is rather cumbersome to use. The window doesn't remember it's size settings, depending on your layer/image/surface name length you may have to resize that window every single time you go in there. And you can set colors only one by one, whereas you can change visible ticks for multiple layers at once. Usual user interface problem in TBC. It's botched together, it works to a certain degree, so no developer will look at it again, but it's cumbersome to use.
This is one of the topics on my ever-growing annoyances/bug list our dealer gets nearly every week from me. There are so many bugs and annoyances when it comes to drafting and plotting.
