Hi All. I am trying to migrate some of our survey processing from Civil 3D to TBC. One thing that I am failing at currently is how to scale a block based on the following example.
We use a tree code with the following syntax: TRD 15 20. Translation is a Deciduous Tree with a trunk diameter of 15" and a canopy radius of 20'.
Is there any way in TBC to use this same syntax to get my tree block to scale by the second number? (20 in this case)
Thanks!
