 Breaks in surfaces between to contours
Jump to  Best Answer
Mark Turrin's profile image
Mark Turrin posted 06-23-2025 18:58
These 2 contours are a 1 foot difference in elevation and yet no surface net is going across this large gap.  Why could this be happening.  This surface is categorized in design and named Finish design.
Tylor Foster's profile image
Tylor Foster  Best Answer
In my experience - if the triangles are not being drawn it is because the "edge length" distance is not long enough to match the actual distance between those contours. I'm assuming the site is pretty flat and these contours have a good amount of distance between them.
Get into the properties of the surface and change the edge length distance to something greater until it draws the triangles
