Since you're chasing an even 1" offset to one side you could try my attached multi offset macro.
Assuming that all rectangles are defined the same way (clockwise/counterclockwise) you just need to offset in one direction. If they are mixed then offset in both directions and choose the right line in the field.
And double check the offset, I'm developing for meters but it should work with feet as well.
I'm still working on the correct elevations in tight kinks, but I assume that your line work is at zero and elevation not really important anyway, am I right?
As always, unzip the attached file somewhere into "C:\ProgramData\Trimble\MacroCommands"
