 Command - EditShareableSlopeTable not pulling up slope tables to be edited???
Tylor Foster's profile image
Tylor Foster posted 11-11-2022 11:52
I'm trying to edit a shareable slope table that needs some updates based on some new plans.
When I try to select the command either from the ribbon or command pane, nothing happens.
* It seems the edit comes back once you create a new one, but it will only be for the slope table you just created in that session. Also some special digging revealed you must edit the alignment, go to SE tab, click the SE button to bring up the SE diagram, now the lines are selectable and editable in the properties. They are defaulting to layer 0.
David Olander's profile image
David Olander
Looks like you got your problem solved, but I want to add a couple things.
  • This issue used to frustrate me a little bit until I realized that, since the slope table is associated with the alignment, we have to select the alignment for the button to activate and them to appear in profile view
  • The "_EditAlignmentAsSpreadsheet" macro includestabs for the slope tables and can be an easier way to get data into it depending on your workflow.
